power steering fluid
Old Jun 23, 2005 | 11:14 PM
LT1FORFUN's Avatar
LT1FORFUN
Default power steering fluid
any substitutes for PS fluid on 1992 model
ATF ok?
Thanks in advance
Old Jun 24, 2005 | 02:18 AM
86PACER's Avatar
86PACER
I know guys here use AFT.
A quart of GM power steering fluid runs about $6.00 each at my local GM counter. Wonder if you have to flush out all excisting power steering fluid before you add AFT or not.
Old Jun 24, 2005 | 08:46 AM
c4cruiser's Avatar
c4cruiser
I wouldn't use ATF as a replacement for PS fluid. It could cause leaks and/or seal damage. Most parts stores carry specific PS fluid in small bottles.
The GM stuff is P/N 12345866
Old Jun 24, 2005 | 12:19 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I hear the Lucas Power steering fluid stops pump moan, morning sickness and minor leaks. I'm gonna' add some to my rack this weekend.
Old Jun 24, 2005 | 05:40 PM
pwrful c4's Avatar
pwrful c4
Valvoline makes a excellent power steering fluid .
Old Jun 24, 2005 | 05:53 PM
Grace91's Avatar
Grace91
Old Jun 24, 2005 | 06:08 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I used their Syntec fluid for a while. No problems. Now I use Royal Purple full synthetic. The way I drain mine is to loosen both lines at the rack and let it drain. Then I work it back and forth (engine off of course!) to squeeze the rest out. Full fill is one qt. This gets nearly all of it out. I had just a smidgen left in a qt. bottle after refilling.
Old Jun 24, 2005 | 10:11 PM
rws.1's Avatar
rws.1
Valvoline Syntec Semi synthetic works great in my '88
Old Jun 24, 2005 | 11:13 PM
Fuzzy Dice's Avatar
Fuzzy Dice
When i first got my vette I chased all over to find the OEM synthetic...finally found a dealer who had it...$8.50 a bottle!...got home and read the label..."part synthetic" same as the Valvoline...took the damn OEM back and got the Valvoline at Autozone for like $2.50 a bottle...live and learn...
Old Jun 25, 2005 | 02:56 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Mobil 1 ATF here.
Old Jun 26, 2005 | 02:34 AM
Reddy94's Avatar
Reddy94
Mobil 1 also... No problems...
To power steering fluid
