What part did I break?
Old Jun 23, 2005 | 11:56 PM
brookman's Avatar
brookman
Default What part did I break?
'88 l98 Passenger side head between the last two cylinders.
Old Jun 24, 2005 | 02:12 AM
86PACER's Avatar
86PACER
That would be the coolant temp sensor that sends the temp to your instrument panel temp guage. It is on my 86 anyway. Did you break off the spade connector?
Old Jun 24, 2005 | 02:50 AM
brookman's Avatar
brookman
yes, I had the head sitting on the garage floor and rolled it over and the terminal popped off.
Old Jun 24, 2005 | 03:12 AM
86PACER's Avatar
86PACER
One of your local parts stores should carry it. Broke the spade terminal off mine too when I pulled my heads off once. Got mine at a local Carquest for less than $10.00. Just take your old one with you to make sure they are giving you the right one. Its common that they instead will bring out the other temp sensor that is threaded in the front of the intake that sends the reading to the computer. Only the one in the head has a spade terminal.
Old Jun 24, 2005 | 09:18 PM
brookman's Avatar
brookman
Does anyone have a non-AC delco part number for this sensor?
Autozone only shows the front one for the computer.
Old Jun 25, 2005 | 12:49 AM
_twisted_'s Avatar
_twisted_
Link 1 or link 2
If they are not the correct one, have them stop calling it a sensor, have them search for a sender.
The above links are for an 86, go there and type in your year etc and see what comes back to ya.
To What part did I break?
