door panel removal---help
Old Jun 25, 2005 | 04:37 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default door panel removal---help
How do I remove the door panel on a 94 coupe? I am attempting to replace the outer upper on the doors. I cannot seem to get the door panel loose. I removed the screw behind the door handle... Something still has hold of the panel.
Old Jun 25, 2005 | 05:25 PM
96redvette's Avatar
96redvette
There is a screw behind the light, 2 inside the small plastic piece on the armrest and one behind the plastic door lock lever (the part that you push left/right with your finger.
hope that helps
Old Jun 25, 2005 | 05:33 PM
dndrsn's Avatar
dndrsn
Yep. This one is easy to miss.
Old Jun 25, 2005 | 06:41 PM
grayml's Avatar
grayml
I've removed my panels many, many times. Be VERY careful, even after doing it many times it is easy to forget to remove a screw, and the plastic panel cracks very easy with age.
Old Jun 25, 2005 | 06:51 PM
Draven's Avatar
Draven
St. Jude Donor '14
Old Jun 25, 2005 | 10:51 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Another question about that certain screw...
Thanks a million guys!! That is good to know... Now here is another question for you. The little slide indictator? aka the thing with the white diagonal striping. How do I get to the screw behind it?? DRDSN, it looks like you removed it to get to the screw?
Dang, GM can hide this screw but they can't design a door panel that will fit tightly and not flop around???
Old Jun 26, 2005 | 12:19 AM
dndrsn's Avatar
dndrsn
I popped it off with the screwdriver i'm holding. It snaps in place on the rod you see in the pic.
To door panel removal---help
