Summertime overheating...
Old Jun 25, 2005 | 04:37 PM
Rinker96LT1's Avatar
Rinker96LT1
Default Summertime overheating...
I have a 96 vette, on an average drive with some hard accelerations here and there I normally run around 190-195*. But yesterday I took her out and went on a normal drive it was 95* out and w/ a/c on I was running at 227*. I thought something as wrong so I returned home. So today I took her back out, another 95* day, and she was running at 192* but as soon as I turned a/c on it started climbing and stopped around 225-228*. Should I have her looked at or is it acceptable for a/c to cause this large of a jump in operating temps.
Thanks,
Jim
Old Jun 25, 2005 | 04:56 PM
Morley's Avatar
Morley
Check for carp between the condensor and radiaror, if that is clean, try a high flow thermostat (Robert Shaw or the like) and flush the cooling system when you do.
Old Jun 25, 2005 | 05:04 PM
hippy's Avatar
hippy
Fish?
Old Jun 25, 2005 | 05:13 PM
VenkmanP's Avatar
VenkmanP
Originally Posted by hippy
Fish?
I had a mouse living there once. Maybe he lives in a coastal area...
Old Jun 25, 2005 | 05:15 PM
VenkmanP's Avatar
VenkmanP
That is not normal. A/C usually brings the temp down if anything because it forces the fans on at lower temps.
Are the radiator fans running when the A/C is on?
Old Jun 25, 2005 | 05:18 PM
RIISITAS's Avatar
RIISITAS
My 96 runs between 195 and 205 degrees pretty consistently with the A/C turned on. That's running here in Vegas with temps up to 110 degrees and higher. Have you taken a look under the hood and verified that both of your cooling fans are coming on with the A/C activated? Without the A/C on your cooling fans should come on at 228 degrees. You might also want to take a look and see if your radiator has been obstructed by some debris. You'd be surprised how much junk can get caught up in the radiator like plastic bags etc. Take a look and let us know what you find.
Old Jun 25, 2005 | 08:32 PM
mikenfl's Avatar
mikenfl
=RIISITAS Take a look and let us know what you find.
Yeah, especially if it's a carp!
Sorry, I couldn't help myself. I'm so ashamed.
Old Jun 25, 2005 | 08:57 PM
Rinker96LT1
Thanks for the replies, I just got back from a ride so the engine is still hot to the point that the fans are on at start up. I'll wait a while and see if the fans come on with the a/c. As far as debris goes, I just looked and found one small leaf and nothin else, not too many bugs either, pretty clean. So I'll post up in a little while about the fan activation failure senario.
Thanks again,
Jim
Old Jun 25, 2005 | 10:12 PM
RocketSled's Avatar
RocketSled
Thanks,
Jim
Follow EVERYTHING here:
https://www.corvetteforum.com/techti...D=53&TopicID=2
To Summertime overheating...
