Atten: 400cid owners/builders - I need pointers
Old Jun 25, 2005 | 08:17 PM
darkman5001's Avatar
darkman5001
Default Atten: 400cid owners/builders - I need pointers
I am planning on building a stroked 400cid for my 86. I am still in the planning process, but I am trying to figure out best brands of parts to use and such. First of all, I need a 400 block. I was looking on Summit and Jegs, and they want like $2200 for just a block. I know some of you probably just have a stock chevy 400cid worked, so I was thinking of doing the same. Where can I find one that I can have machined and all by a machine shop? My plans are to use AFR heads. I don't know which ones to get though. I plan on stroking to possibly 430cid, and I might want to supercharge later, like 5 years or more from now. I need to decide which AFR heads I should get. Also, is an engine with a knock sensor better than one without one, and can a 400 block be adapted to use a knock sensor? Can the 86 stock ECM be used to run a 400cid? I am thinking a SCAT forged crank might be my best bet, but I need opinions of the rotating assembly. What brands are better and most reliable? I want forged internals. This setup must be able to pass emissions, unless I can find a way to get out of emissions. I will be using my current exhaust setup, which is in my sig. Either way, it will be street driven alot, so it must be streetable. I can rebuild stock motors to spec, but as far as custom and modified, I am a newbie, so I need help on part selection and compatibility. I am aiming for low 11s on the setup, but 10 seconds would be awsome too. Let me know what you guys think. Thanks!
Old Jun 25, 2005 | 08:34 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
If you do a search on my user name it should turn up a good many posts about how our 406 ran, and the combinations that made them up. Also I have a website in my signiture that should walk you through the many stages of my car, including the 406.
These setups ran VERY low 11s and High 10s.
If you need any assistance I would be more than happy to help you out. Just shoot me an IM.
And welcome to the forum
Old Jun 25, 2005 | 08:41 PM
red L98's Avatar
red L98
Old Jun 26, 2005 | 08:07 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Originally Posted by red L98
You can make a 434 out of a stock 400 block, we biult one last year. I would just go with a 406 nothing more. My brother and I both have 434 and it takes a lot of cylinder head to make them work well. I have 4 400 blocks that I can sell you one. If I was to do my brothers motor again I would go with a 406 and spend the extra money on the cylinder head because that’s what makes power. My friend just dynoed his motor last night and it made 605 HP and 637TQ on an engine dyno. His motor was a 406, AFR 227 and a 250-260 / 650 lift cam at 110. It was a carb motor and it runs good. About using a stock ECM and knock sensor, you can make it work just as easy as building a heads and cam 350 . The knock sensor bolts in just like the stock one did in the same location. and the stock ECM will work great if you get it tuned by the right person . My brother’s 434 was tuned by Jesse ski_dwn_it and it goes 11.04 at 128 MPH with stock ECM and a mass air. Scat makes good stuff but I would run Eagle stuff. If you plan on using a stock block you need to get splayed main caps and dowels pins put in the block to hold the main caps in place and don’t get a stock 4 bolt 400 blocks they are junk. Make sure its internally balanced. If you want to go with a big stroke I would fill the block about 2 inches to help strengthen the spots where its needed to be clearance .
I agree 100% with the comments about using the stock 400 block. If you want to go bigger than 406, you'll be safer with an after market block. And with the power you are looking to make, I would definitely splay the bottom end, which more or less requires you starting with a 2 bolt block.
Scat does make decent parts, but I also ran Eagle in my last 406 and was very pleased. As a general statement, Eagle isn't the lightest rotating assembly you can buy or even the strongest, but it is great stuff and will last in a street/strip motor for a long time.
A great friend and forum member has a 406 one of his cars with a GM block. He's got Callies crank, Oliver Rods, and JE pistons, and a splayed bottom end. Not the cheapest route, but he has hit it with some serious N20 and its been together for several years.
Old Jun 26, 2005 | 11:54 AM
darkman5001
How much did it cost you to build your 434, and will my Hooker 2149 hedders work on a 434? I am trying to see which way I want to go. How much would it cost to set up a 406 block? Was your old 406 block a stock chevy block, and how much did it cost to prep? Thanks!
Old Jun 26, 2005 | 11:55 AM
darkman5001
How much are you looking to get for one of those blocks?
Old Jun 26, 2005 | 12:10 PM
Upstate's Avatar
Upstate
From: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
Am waiting on cash to follow a similar route....
Don't forget about the balancer. The cross member needs to be clearanced for the larger diameter. A BFH will work for this, or a smaller balancer for external balance, of which I haven't found yet, but I am sure they're out there. Of course if you go internal balance (which I would try to do) you won't have that problem.
Where did you 400 guys put the sending unit that's above the oil filter? Did you just tee it off behind the distributor? My 406 is in a crate in the garage and it definitely doesn't have the hole there, but it looks like the boss is there. I wonder if it's safe to drill and tap it...
Old Jun 26, 2005 | 06:11 PM
bigjack's Avatar
bigjack
Default suggestion
You may want to check some of the "kit" engines. Sometimes they are cheaper in the long run when considering they might include balancing, block prep, hot tank, cam brgs., bore/hone,oil pump,pan, gaskets,paint,etc. One I recall is Scott Shafiroff in NY(has web site). I think you'd want a stout base engine if contemplating the blower, etc. later. Think about a carb vs the fuel inj. Chip burning, intake & runners, plenum, appropriate cam, vs the old school carb $ ???? I don't know about hood clearance though. Good Luck
Old Jun 26, 2005 | 07:58 PM
red L98's Avatar
red L98
500 pickup only
Old Jun 26, 2005 | 08:00 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
We just did another 434 for a forum member and your looking at about 12-14k installed. But this is using the BEST of everything and you will have a motor that *could* run 8s with a good shot of nitrous (300shot) in the right chassis.
The price seems high, but when you add up EVERYTHING you will need, plus the cost of the installation, its actually pretty cheap.
This is going aftermarket Dart little M block,balanced and blueprinted to withing 1/2 gram, well basically everything in my signiture.
Here are some photos of the motor we just put together and that I actually JUST got done installing and its about to light with a the installation of the header gaskets and a few other small things.
Right now we have two of these running and they both run bottom 10s in full weight C4 cars.
Old Jun 27, 2005 | 10:04 AM
darkman5001
VERY NICE. How much did that motor there cost to build?
Old Jun 27, 2005 | 10:22 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
First sentence of the previous post.
To Atten: 400cid owners/builders - I need pointers
