tranny or torque converter???
As I was driving, all of the sudden it would act as if I was in neutral. I would just roll to a stop. I couldn't drive forward or backwards. I COULD put the gear shift into forward or reverse, but the car would not drive on its own. (I could hear a grumbling noise, coming from under the car, sounding like it was coming from where the engine and the torque converter meet. This wasn't the whinning sound that you get from having a dirty transmission filter or from being low on transmission fluid.)
I turned the engine off, re-adjusted the shift points, and could drive for about 2 blocks, before it started all over again. (Each time AFTER I re-adjusted the shift points, and BEFORE I drove again, I wouldn't hear the grumbling noise, until it messed up again.)
I am thinking that if the transmission is out, adjusting the shifting points shouldn't make a difference. (or should it?)
Could it be that I have a bad torque converter? How do you know if it is the converter or the tranny?
RACE ON!!!
I adjusted the TV cable.
Thanks for the input. (even though you are being sarcastic.)
RACE ON!!!
At this point, we are left with a few options;
come back with a sarcastic remark, (and offer no help),
come back with a sarcastic remark, and offer helpful advice, (which you did),
or just offer helpful advice.
Myself, I'd take the latter.
Anyway, like I said, you do know about vettes, and the advice is always appreciated.
I have always appreciated your expertise, and you do appear to know "vettes", but do you REALLY think that I (or anyone else) would stop every two blocks, jack up the car, remove the governor, and change the weights and / or springs? Does this sound logical? Since it doesn't, maybe one would stop to consider that I probably incorrectly stated what I had done to attempt to remedy the situation.
Since fluid level was up and changing line pressure got it to move some, I would bet on a problem within the A4 though I have no clue as to just what is the issue. Since you heard some nasty noises from underneith you likely have some loose or broken parts within. As mentioned, for this reason you should also replace the TC and get a thorough flush of the system along with the rebuild. I recently had the 3-4 pack go out in my A4 and this is what the rebuilder did.
Was the 2004 rebuilder a tranny chain or a trusted performance shop? If not the latter you might want to seek out such and get a performance rebuild this time.
Good luck and let us know what they find on this one please.
Should of known better.
In general, how long of a warranty does a performance shop usually give on one of their rebuilds?
Before I did the 2004 rebuild, when I would shift the car from "park" to "drive", my car would kinda try to lunge forward. It couldn't go anywhere, because my foot was on the brake pedal. (It was almost like my RPMs were too high). I thought the rebuild would fix the problem. It didn't.
Any ideas?
Indeed the shop that did my rebuild flushed the lines thoroughly to remove particulates. I don't know if the discount chains do this or not but, from past experience with AAMCO (1yr warrantee and the rebuild died about 1mo after the 1 yr period), I'll never take a car to one of those.
The lurch on shifting from P to D is likely due to the IAC causing too high of an idle, or maybe the TC has too low of a stall. If normal idle is ok, ie ~700-800rpm ask for the shop to install a 2,000rpm 12" lockup TC.
What year Vette??
As it turns out, the problem with my transmission was that I had more crud clogging up my tranny filter.
Because I only had 4,000 miles since the April 2004 repair, and the warranty was for 12,000 miles, I wasn't charged anything for the repair. Not even the towing fee.
Since my ATF level was good, and my Haynes manual said to replace the filter every 30,000 and/or 24 months, I didn't even think to check the filter.
I appreciate everyone's advice on this matter.
