Sorta doesn't like the A/C
Old Jul 13, 2005 | 09:29 AM
  #41
FD2BLK's Avatar
FD2BLK
Originally Posted by Nathan Plemons
The early Holley TB's had the IAC passage that just vented to behind the throttle blades instead of forcing it through the IAC passages in the intake. Reaming the hole slightly larger and installing a piece of copper or brass pipe would effectively block the passages to the intake and force all the IAC air to go through the idle circuit in the intake.
THanks if I get the chance to pull THe TB this weekend I wil do the mod if needed
