headlight relays
Old Jun 28, 2005 | 07:31 PM
Funniman250x's Avatar
Funniman250x
Default headlight relays
i have an 84' and have had problems with the drivers side headlight always staying up. not on. but it wont go down. i talked to some guys at 'corvette and classics' and they said switch out the relays and find otu which relay is bad if it is the relays, butttttt i cant find the relays! does anyone have any pictures? i know there are 2, one is the motor relay and the other is the transistor relay? i found the motor relay i believe, its on the botom of the actual headlight motor, but wheres the other? someone please help, if anyone has any pictures that'd be great too, thanks.... Jeremy
Old Jun 29, 2005 | 02:32 AM
jan-erik's Avatar
jan-erik
Hi.
I have an 85 and had problems with the right headlight. The most common fault is the headlight motor. Inside the assembly there are some gears that may be worn. That is a very common fault. These gears you can buy from several suppliers. I had a combination between these gears and some dirty contacts inside the headlight motor assembly. I do not think it is any outside relays.
Old Jun 29, 2005 | 09:30 AM
Funniman250x
i dont think it is the gears cause you cant hear the motor working when you hit the switch. it has fallen down once before when i hit a bump goin down the road.
Old Jun 29, 2005 | 09:37 AM
7thvet's Avatar
7thvet
The relays, 3 of them are located on the front of the drivers inner fender panel.
I prefer to use a long pair of jumper wires and just run the 2 wires from one headlight motor to the other & try them.
If the same one fails in the same manner then its the motor but if the other one inherits the problem then its the relay.
The top relay works the bottom 2 relays.
If you dont have those 3 relays & only have one black box. then that means someone updated you to an 88 model.You can still test with jumper wires from motor to motor.
Check electric connections.
Old Jun 30, 2005 | 11:35 AM
Funniman250x
so where exactly should i place the jumpers on the headlight motor? then hook them up to the relays one at a time?
Old Jul 2, 2005 | 03:53 PM
Funniman250x
I've fixed it!!!!! well it was pretty stupid actually. I was reading in the manual how you could manually turn the headlights up or down by twisting the *** on the bottom of the motor. well clear enough the *** was just a little too tight, so i loosend it up a little and prestooooo. thanks for your help though guys.
To headlight relays
