A/C Compressor question
Old Jun 29, 2005 | 06:53 AM
cajun86's Avatar
cajun86
Default A/C Compressor question
On an 88 vette the A/C compressor has a pop off valve on the top of the compressor on the high side has anyone ever have this valve leak ? The valve appears to be replaceable since it screws out.
Old Jun 29, 2005 | 08:17 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Maybe SunCR (one of our resident HVAC experts) will chime in. I've gotten some great advice from him lately.
Old Jun 29, 2005 | 12:29 PM
SunCr's Avatar
SunCr
If it does, I'm unaware of it. System and the Nippo 10PA20C relies on a high pressure switch which will cut power to the clutch if the high side gets above 420 psi. If that high side tube is leaking, may be able to replace (you might have to buy the whole manifold) at www.acsource.com or www.ackits.com although the only parts I've ever found for it is the shaft seal kit.
Old Jun 29, 2005 | 01:02 PM
cajun86's Avatar
cajun86
Went to an AC Delco parts house and picked one up for $20. this valve just leaked the system down, the car hadn't even been driven in a while let along had the A/C on. When i tried to add freon the valve was spitting so to speak everytine the clutch would engage. O well i'll just pull a vaccumn and fill it up again.
Old Jun 29, 2005 | 01:38 PM
onedef92's Avatar
onedef92
Probably wouldn't hurt to change the accumulator/filter, either.
Old Jun 29, 2005 | 02:07 PM
pwrful c4's Avatar
pwrful c4
Time to do the whole job to be safe.
To A/C Compressor question
