unstable idle ('86)
Thanx in advance.
I assume around that temp is when it changes circuits.
Today I was running the car in the garage after re-filling my coolant and I got a service engine light up for code 44 (lean mixture, check O2 sensor). This one cleared itself after I started the car back up. What is the average life of an O2 sensor? I imagine, judging by the rest of the maintenance levels on my car, that the sensor is original with 120k miles on it now.
I also occasionally get a hesitation on acceleration (just like one you would adjust your carburetor accelerator pump to eliminate)
The seal on the idle screw has been broken so I assume the idle screw has been adjusted.
If there was a vacuum leak then would it not be noticed during cold idle (open loop)? Or is cold idle rich enough to work within the parameters with a small vacuum leak that would affect the closed loop?
If it is not a vacuum leak then I guess the hunt would be through the electric sensors of the closed loop, right?
Let me reiterate that I doubt that the O2 is causing these problems, but it is one that is read during closed loop. More than likely its going to be TPS, dirty TB/IAC, or bad vacuum leak.
1. Clean the throttlebody Butterflies and the walls for carbon deposites.
2. Clean the IAC valve and the connection from the throttlebody to the valve.
3. I had a bad EGR valve. Vacuum membran was bad.
4. Then after not finding the reason for the bad idle I searched for the vacuum leak. Should have done that first. I used start gas and spryed some over the runners at the intake manifold and the engine increased the idle. So, I had to take the runners off and with new gaskets it became good and the idle is now .ok.
