carbed guys! PLEASE ENTER
thanks in advance
CHRISTOPHER
P.S do I need shorter cables(these things look way to long
When I put my carbed 406 in my S-10 I was able to retain the throttle cable and use the TV cable that was in the trans by using the brackets from another carbed vehicle. It required some modification of the bracket to work correctly. I know the aftermarket supplies these brackets, and edelbrock comes to mind, I am sure Holley has them too.
Try to get the adjustable unit if it all possible. I assume you're using the 700R4. TV cable geometry is another important aspect you don't want to over look. You'll have to do some googling on that one though.
Cable length for the throttle isn't an issue if you can get it routed to the carb without binding it up. TV cable length can be an issue as the vette cable is longer (in my case about 6"). This one cable you don't want to mess around with and want to get it as perfect as possible. If you can get to the bone yard try getting a TV cable off of an 80's carbed chevy pickup with the 700 (mine was from an 85), you could get a throttle cable too but I am not sure if it will work with the vette gas pedal. The brackets for the cables would be a toss up. I have no idea what vehicle my bracket came off of but it required a lot of cutting and bending to get it right. I no longer have my truck but still have the engine. If the bracket is on there I'll post some pics for you when I get home later this evening.
http://www.tvmadeez.com/article/index.php
(also look at the holley 4100 or spreadbore links on the left)
more info:
http://www.artcarr.com/instructions/...structions.pdf
also, on this page are
700R4 & 2004R Holley® carburetor TV Cable Bracket 376705
and
Holley® carburetor TV Cable geometry corrector kit 376715
