Today's optispark thread - checking high res wire at ECU
Old Jul 2, 2005 | 12:58 AM
ScaryFast's Avatar
ScaryFast
Originally Posted by SJW
1. A fault in the "Run" circuit of the ignition system. Sounds as though it's possible you have power to the ignition system when the switch is in Crank position, but not when it's in Run position.
SJW, you mentioned this earlier and I didn't pay attention to it. Let's explore this option further. I don't have a key cylinder, only an ignition switch and a start button. When the ig switch is on any circuits powered by ignition should get 12V. This would be equivilant to the run circuit being active at this time, right?
The crank position of the key is replaced by the start button, so as long as the car is on and not in crank it should be in run. How would I check your suggestion? I assume that any line powered by ignition should have 12V regardless of whether the car is running or stalled (which they do). Is that what you meant?
Old Jul 5, 2005 | 07:56 PM
SJW's Avatar
SJW
I think you're thinking correctly. It's possible that there's a problem somewhere in the wiring that could allow the ignition switch to supply +12v to some circuits, but not others, but I'd have to stare at a wiring diagram for some time to be able to make sense of that. The fact that your electrical system has been substantially modified does raise some questions about this, though.
I don't have my manuals here in front of me, but I'd think there's someplace you can check for the presence or absence of +12v feeding the ECM and/or whatever else is required to provide juice to the ignition system when the key is in Run position.
If I understand correctly, you have the lock cylinder removed from the column, but have retained the stock ignition switch in the column, and have remote-mounted a momentary pushbutton starter switch. If this is the case, maybe you'll want to try to briefly hold the ignition switch in the Start position (with a screwdriver) while you try to start the car, and see if that gets it to start and run.
Have you verified that the fuel rail is adequately pressurized?
Old Jul 5, 2005 | 08:01 PM
SJW's Avatar
SJW
I never actually had a 36 or 16 code, I just probed the lines with a DVM and assumed based on what the manual defined as the problem I assumed those codes would be there. I wasn't able to check codes until today when I borrowed the scan tool and only had the two listed above.
I just tried to start the car again and it is back to the run for 2 seconds then stall.
The issue happened once months ago and then everything was fine until recently, which is why I assumed it was the powerwash ruining my Optispark. I was convinced of this based on everyone's input until I saw no opti codes today.
I will check all of the voltages on the circuits handled by QDM tomorrow and look for shorts. I have a large current draw which could also be explained by a problem in the fan or A/C circuits. Then it's full diagnosis of the ignition system and perhaps ultimately replacing the ECM. However, would problems with the ignition system or ECM be intermittant?
There are many connectors dangling unplugged in the engine compartment from the gutting, I'll also trace all of them back and remove them from the harness.
I just can't believe it's the fuel system since twice in two days the car has ran flawlessly for an extended period of time. Those types of problems are not intermittant...it HAS to be electrical.
Bear in mind that the fuel system IS electrical. It's very possible that you have an intermittent connection someplace in the system that feeds the fuel pump, or a balky fuel pump relay.
Get the car to misbehave while you have a FP gauge in place, and then you'll be able to either rule out, or verify, a FP-related problem. If FP is good while the car dies, look to the ignition system and forget about the fuel system. If the FP is not holding good while the car dies, forget about chasing ignition gremlins.
Break the problem in half first -- figure out what's happening (or not happening) with the fuel system, as it's easy to diagnose and troubleshoot.
Old Jul 5, 2005 | 10:25 PM
ScaryFast's Avatar
ScaryFast
Damn your logic! Makes good sense.
Ok, check here for the latest. I've ruled out the opti so I'm back to wiring and these suggestions discussed in this thread. I've sent an email to you (because I can't remember how to post pics in a thread) showing my ignition set-up. I have removed the stock column entirely.
http://forums.corvetteforum.com/show...18&forum_id=48
Fuel pressure checks out so it's on to injectors and/or ECM.
Thanks again!
Old Jul 6, 2005 | 08:03 PM
SJW's Avatar
SJW
I replied to your direct email about this last night. Lemme know if you didn't get it, and I'll try again.
SJW
