block change into 85
Old Jun 30, 2005 | 10:26 PM
Fasterer's Avatar
Fasterer
Default block change into 85
Picked up 1988 roller cam block for my 85. only problem was it was tbi.
will the heads work with my tpi. anyone out there done this?? What else have you run into. I do want to go to roller rockers and i will be replacing the cam no matter its condition. very low milage on 88. it was out of wreck. my 85 is bone stock. I have heads off 88 and valves are like new. No ridge in block at all.Looks like it could be run as is but it is going to machine shop for at least honing and a good clean up. Any suggestions ???
Bill
Old Jul 1, 2005 | 12:31 AM
bogus's Avatar
bogus
get yourself a pair of aluminum 113s... a little later vintage, but much better then the iron ones on your motor.
and used ones are cheap.
Old Jul 1, 2005 | 01:07 AM
vettefun's Avatar
vettefun
I think he already has them, he stated he's got 88 heads so should be good improvement over those irons, especially with some RR's.
Old Jul 1, 2005 | 01:14 AM
bogus's Avatar
bogus
yea, but the 88 was a TBI motor, not TPI... isn't there a difference there?
If not, use those heads.
Old Jul 1, 2005 | 01:21 AM
vettefun's Avatar
vettefun
Good point.... I'm not sure with a TBI motor
Old Jul 1, 2005 | 01:30 AM
artvette's Avatar
artvette
Huh???
Old Jul 1, 2005 | 01:31 AM
Bilyk's Avatar
Bilyk
Are you asking if a TPI manifold will fit on an 88 roller block/heads that originally had TBI? If that is your question, then the answer is yes. I dont see why they wouldn't. A smallblock is a smallblock
Old Jul 1, 2005 | 01:34 AM
vettefun's Avatar
vettefun
Also wondering if the heads off an 88 TBI he picked up would be 113 castings like on the Corvettes.
Old Jul 1, 2005 | 01:37 AM
Bilyk's Avatar
Bilyk
I'm no expert (and can't find my interchange manual right now) but I don't think so. I don't think anything other than corvettes got corvette heads.
Old Jul 1, 2005 | 02:19 AM
Morley's Avatar
Morley
your 85 intake manifold won't fit on 87+ heads, they have the revised bolt angle on the 2 center bolts on either side. You can elongate the manifold holes to make it fit. The TBI heads are probably the crappy "swirl port" heads, junk.
If you were to get a set of alumnium heads from a corvette you'd be able to keep your intake as is.
Old Jul 1, 2005 | 02:50 AM
yellow dragon's Avatar
yellow dragon
i ran heads from a 95 LT1 vette on my TBI motor, fit great and gave me a lot more torque
Old Jul 1, 2005 | 04:36 AM
rodj's Avatar
rodj
Aren't the TBI engines ,truck engines like the Vortec?
Iron head / roller cam
Old Jul 1, 2005 | 08:42 AM
Bilyk's Avatar
Bilyk
ohhhh yeah
he's right
my apologies
Old Jul 1, 2005 | 11:10 AM
CFI-EFI's Avatar
CFI-EFI
For the iron heads. Also, you will have to use the flywheel or flex plate from the '88. In 1986 Chevy went to the one piece rear main seal which changed the bolt pattern on the rear of the crank and the method of engine balance.
RACE ON!!!
PS. Vortec engines are not TPI. They are CPI. The Vortec was introduced in 1996.
Old Jul 6, 2005 | 11:32 AM
Fasterer's Avatar
Fasterer
Default more info
Thanks for the info. Been away from computer. Its deff a roller cam 88 with iron heads. When i get it done what would i have to do to ECM to carry the new flow or will 85 setup even start to handle it. The injectors are brand new 22lb. the rest is stock setup.
I have the flex plate and harmonic balancer from 88 so that should not be an issue. Anything else anyone can think of??
Old Jul 6, 2005 | 11:36 AM
scorp508's Avatar
scorp508
88 what? Corvette? Camaro? Ferrari? Buick? Grand Wagoneer?
Old Jul 6, 2005 | 12:12 PM
Fasterer's Avatar
Fasterer
Default more info
All i know about the block i posted. I ran a search on the # and it shows chevy all as used in. I can post the block casting # if it would help. I picked it up to upgrade my 85. From previous info i can see the heads have to go. The block is being dipped and checked and new cam bearings and bored if all is well with it. I only gave my obsevation on condition as i had not much else to go on. it seems to heve lived a very short life. I was told it came out of a wreck and after seeing internal wear i believe it.
To block change into 85
Old Jul 6, 2005 | 02:37 PM
cv67's Avatar
cv67
St. Jude Donor '05
88 vettes used the TPI
Old Jul 6, 2005 | 02:42 PM
Togo's Avatar
Togo
depends - pre 96 motors were NOT vortech - i know this because the year after i bought my 95 chevy, they came out with the 275 HP vortech v8 in the 96 trucks!
you should just sell your 88 roller block and buy this
http://forums.corvetteforum.com/showthread.php?t=962577
Old Jul 6, 2005 | 09:04 PM
shadetreeperf's Avatar
shadetreeperf
TBI engines were also put in caprices and camaros. I agree with the center intake bolts having the revised angles, the '85 intake "could" work on later heads, but like someone mentioned, there would need to be some grinding done. If you don't go too crazy with the cam (nothing with much more duration than stock) the ecm should run it OK, since it is a MAF setup, although you would probably need some tuning (tuning is a good idea anyway).
KC
