power steering pump leak
Old Jul 1, 2005 | 11:53 PM
jp2002ls1's Avatar
jp2002ls1
Default power steering pump leak
I blew my power steering pump on a road course and I can't figure out exactly what happened to it. It is blowing past the valve fitting that the pressure line screws into. Does anyone know what would cause that? I checked the O-ring and it looked fine.
I'm going to replace the pump but it just stumps me as to what happened, I could understand if the line was leaking at the end or if the front of the pump blew out but this just has me stumped.
Old Jul 4, 2005 | 02:36 AM
OOPS!'s Avatar
OOPS!
Default me too!
My 92vette leaked the same place at tsukuba circuit JAPAN last satureday. I checked the O-ring 2 times and it looked fine but leaked again(T T)
I ordered the pump to corvette central. I think the check valve worn out. But it iooked fine ..(T T)
Old Jul 4, 2005 | 08:28 AM
RichS's Avatar
RichS
The line cracked at the point where the jamb nut holds the line in. If you pull it out you will see it looking close at the flair in the line. I broke 4 Gm lines.
After breaking one at Pocono I ordered one from DRM. It is a braided line kit with steel fittings that go into the pump and rack. After putting it on I ran a autox with 9 runs and Khumo race tires. Not a drop out of the line.
DRM website Click on specials. The kit is $99, an new stock hose is around $70 from GM and will break again.
Old Jul 4, 2005 | 11:12 AM
96GS#007's Avatar
96GS#007
As an aside...If you're turning any serious rpms (6000+) during your track sessions, your pump is on borrowed time. I sent mine to Turn One and had it upgraded for $120 plus shipping. They install new guts and modify the fluid flow. You'll have slightly higher steering effort at low rpms but it's a price I'm willing to pay for pump life. Here's a link to their website: http://www.turnone-steering.com/ I called and spoke with Jeff when I was having mine done.
Old Jul 5, 2005 | 06:04 AM
OOPS!'s Avatar
OOPS!
Wow,I found the crack where you adviced !! I replace the line by earl's. Thank you for your advice!!!
Old Jul 5, 2005 | 12:05 PM
vettefun's Avatar
vettefun
Great tips, my pump just starting leaking, when I get off work tonight I'll check there as well.
To power steering pump leak
