Clutch system bleeding??
Old Jul 2, 2005 | 09:06 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Default Clutch system bleeding??
On a '96, what size hose do I need to bleed the hydralic clutch system? I've looked at ZFdoc.com and in my Haynes manaual and all it says to use is a piece of clear hose. Would be nice one of them mentioned what size the bleeder is.
Any help is appreciated.
Thanks!!
Old Jul 2, 2005 | 09:11 AM
Aaron71771's Avatar
Aaron71771
I am guessing 1/4"; 1/4" inner diammater - outer will be larger than 1/4"
Old Jul 2, 2005 | 09:47 AM
c4cruiser's Avatar
c4cruiser
Should be the same size hose needed to bleed brake calipers. I think the slave cylinder bleed valve is the same as on a caliper.
Old Jul 2, 2005 | 12:45 PM
Grace91's Avatar
Grace91
To Clutch system bleeding??
