ERG valve help
Old Jul 2, 2005 | 11:01 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Default ERG valve help
cant get the bolt in the back on my 85 L98. Whats the secret. Do I need a special tool? Thanks
Old Jul 2, 2005 | 11:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Try a high quality open end or box end wrench but first hit the bolt with PB Blaster and let stand over night.
Old Jul 2, 2005 | 11:15 AM
Wayne88's Avatar
Wayne88
This is the way I did it.
I took a 3/8 'claw' wrench, sawed some off.
I wedged a block of wood [2X3] next to it and pushed.
There are lock washers under the bolts and they are on tight , use liquid wrench.
Also, check the size, mine are 3/8--not metric like the rest of the car
Now I'm sure there is a better way, but this is how I did it.
Old Jul 2, 2005 | 11:18 AM
Cruisinfanatic
There's just no room for the wrench (unless it's 3 inches long) and a socket takes up the space between the bolt and the bottom of the valve. You can get a socket on it, but cant get the ratchet on the socket.
Old Jul 2, 2005 | 11:20 AM
Cruisinfanatic
Both a 10mm and a 13/32 fit about the same. I guess I'm going to start cutting my tools up, LOL
Old Jul 2, 2005 | 11:35 AM
Cruisinfanatic
The bolt you have pictured I was able to get with a socket. The one in the rear is the bad one. If I cut a wrench to fit, it's going to wind up only about 3 inches long with room to move only a couple inches.
I just bent the old valve. Now it's easy to get a socket on it, LOL. Now just to tighten the new one. Can't bend that one.!
Old Jul 2, 2005 | 12:56 PM
65Z01's Avatar
65Z01
As you said it takes a very short open end wrench, which I happen to have. Otherwise I would have cut a small open end to length to do the job.
BTW, put some anit-seize on the bolt theads in case you need to get in there again.
Old Jul 2, 2005 | 01:56 PM
Cruisinfanatic
Finally got it with a regular box wrench, but from the opposite side of the bolt. Total time 2hrs 15minutes to replace, 1 hour of that messing with 1 bolt.
Old Jul 2, 2005 | 03:04 PM
Morley's Avatar
Morley
Next time...go see your Snapon man and get a 3/8" 12 point crow's foot, they work great.
Old Jul 10, 2005 | 02:08 AM
Bubba91's Avatar
Bubba91
Get some gearwrench flex heads, they would be perfect.http://www.toolpeddler.com/GearWrenchFlexHead.htm
To ERG valve help
