I was just wondering what the correct tansmission fluid is for my '92's manual transmission.
Why? Becuase of the on-going saga of the engine rebuild, I noticed that in the parts list (Parts & lubricants Used) the shop used 6 quarts of Automatic transmission fluid. Now I have a problem with my tranny.
First off, if the shop put ATF in your ZF6, get it out ASAP. The ZF6 was filled with 5w30 motor oil from the factory, and the ZFDoc recommends BMW 10w60 motor oil.
Also, there is no way 6 quarts of anything would fit in the ZF6. Looks like you got hosed with some phony charges.
Drain it ASAP! Either use the factory 5w30 (not just any 5w30) or BMW Castrol 10w60 only available from BMW.
That I got taken is something I no longer question. But I guess they spilled or pocketed the last 3 to 4 quarts of whatever they charged me with.
What is different from the factory in the 5W30's case? Is that oil something a Chevy dealer readily stocks? If not, is the Beemer version readily available?
The oils are GL rated (gear lube). Regular 5w30 motor oil is not. I like the Castrol stuff because it's synthetic, the GM oil is not. Drop into your BMW dealer and pick up 3 quarts/litres (it needs a little more than 2). There is a FAQ sticky at the top of this forum that contains the part numbers you need.
If you live in a cool climate, and you drive you Vette in below freezing temperatures, you may find the BMW oil makes the ZF a little notchier until it warms up. Some people notice it and some don't.
The oils do have something in common - they have additional friction modifiers that help deal better with the shearing forces inside a transmission.
It sounds to me like your shop is jacking you on that fluid (what else, begs to be asked, eh?).
The BMW oil is available at your local BMW dealer for about $8.00 a litre... it requires 2.1 litres.
Would the regular 5W30 oil be detrimental, especially after less than say 100 miles on the car? (I first noticed it on a drive back from getting help from MarkLT1, where very few miles were on the rebuild)
I saw a Mitchell's recommendation sheet that simply listed 5W30 as the correct fluid for transmission oil, not even a specific part number.
Thanks again - I'll peruse the FAQ area. I'll only be driving this car in dire circumstances when it is below freezing - it gets real cold in the winter with the top down
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
I have run Castrol 10W30 synthetic oil in my trans since new. Gordon Killebrew had recommended to me that particular weight many years ago. The factory fill in the ZF's was actually Kendall 5W30. He told me that running the 10W30 weight would eliminate the gear chatter at idle. He was absolutely correct!
My Vette (which I ordered new in March 1996) now has over 80,000 miles. I have original clutch assembly & original hydraulics. Just this past month, after reading several posts here, I changed the Castrol to the BMW fluid. I noticed a difference right away. I had changed the Castrol every two years. The trans was very quiet and very smooth. With the BMW fluid, the trans is even quieter and the shifter moves even smoother. Better than a knife thru butter.
I live in Chicago and drive my Vette until Christmas. I am not anticipating any difficulty with the colder weather, because I was already running a 10W oil in the trans.
I also run synthetic oil in the differential. Have been using synthetics since middle 70's when Amsoil was the only synthetic available. I am sold on synthetics. The BMW fluid, IMHO, is terrific.
That's a good testament - I think I'll replace what is in there with the BMW fluid, although, sadly, the damage may be done.
I wonder what would be involved with identifying what was really used, whether it was plain old 5W30, or (I hope not) the ATF that was listed on the sheet?
Got the car back yesterday - so far so good - no grinding sound and it's been up to temperature quite easily in yesterday's heat. This evening was cooler, but we tooled around quite nicely. 200 more miles and I'm done the break-in period!!!!
We went with the Castrol. What came out was not ATF, but I'm afraid it was plain old Pennzoil made for GM 5W30 or 5W50.
More miles tomorrow!!!!
