How do I know what option my car cam with from the factory?
I have a 94 and I was wondering what the build sheet was for my car and all the options that were ordered with it?
There should be an RPO sheet either under your center console or under one of the rear carge bin lids. Once you grab those you can then lookup the options it came with.
Received 1,401 Likes
There is also a build sheet attached to the top of the fuel tank, if you dont find RPO sheet inside.
You can order the build sheet and window sticker from the National Corvette Muiseum. Link is below:
http://www.corvettemuseum.com/
The RPO list unded the center console lists both standard and optional items installed on the car. You can decode the RPO codes here: http://www.corvetteactioncenter.com/...o/8496rpo.html
The NCM sells the copies of the build sheet and the window sticker (this is the link to the order page: Build Sheets and Window Sticker The window sticker wil have the options ordered on the car and the prices. It also shows the name and city of the dealer that received the car.
