Cyrogenics for the timing chain?
Old Jul 3, 2005 | 07:51 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Cyrogenics for the timing chain?
Just curious if this would be a viable mod to the timing chains in our LT1's. I am referring to the extreme chains etc, not an OEM, as I would hope when apart I will chainge to the newer stronger type.
Old Jul 3, 2005 | 08:20 PM
mothersworry's Avatar
mothersworry
From everything I have heard, the LT1 race program used the Cloyes True Roller. I think it retails for around $600+. This chain was the only chain that would not break durning the 12 of sebring. It is not cyrno. Hope this helps. BTW how is that cam choice? I went with the same one from Pete.
Old Jul 4, 2005 | 12:59 AM
steve40th's Avatar
steve40th
I really like the cam, pulls very well with my 3.75 geared 2800 rpm stall. Alvin has the tune near perfect, and as soon as I get it on the dyno and give him a wideband data profile, it will get tweaked a little more.
I will probably go with the LT4 extreme, as it is a bolt in and I am useing the mechanical pump.
To Cyrogenics for the timing chain?
