Why does no one port TBs?
Old Jul 4, 2005 | 11:28 PM
SDS Photography's Avatar
SDS Photography
Default Why does no one port TBs?
There is a local guy here who does porting but i have not seen anyone here who has ported theirs. can it be done?
Old Jul 4, 2005 | 11:34 PM
bogus's Avatar
bogus
yes... I am sure alcee1 will chime in!!!
Old Jul 4, 2005 | 11:38 PM
cv67's Avatar
cv67
St. Jude Donor '05
I massaged mine a bit
Does it help? Who knows. Maybe with more mods it will pick up a little something.
Old Jul 5, 2005 | 12:00 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I have a stocker punched out to 52mm. It's done all the time.
Old Jul 5, 2005 | 12:09 AM
SDS Photography
if you port it do you need to have the car tuned?
Old Jul 5, 2005 | 12:20 AM
Corvette Kid
No. If that's all you do, it'll be fine. The concensus is around here, Dave Kuldos does a fine job of this for much less than an aftermarket one. Some of the aftermarket ones are troublesome anyway.
Old Jul 5, 2005 | 02:10 AM
Dan Parker '96's Avatar
Dan Parker '96
David Koldos is the man for stock (48mm) to 52mm. Excellent work and great to deal with.
dkoldos@ameritech.net
Old Jul 5, 2005 | 09:41 AM
FELNGR8's Avatar
FELNGR8
With my LT1 I did have to have the car tuned. As the last mod I made after heads/cam and headers the PCM could no longer manage the changes with stock tune.
I have a heads/cam upgrade and on a previous dyno session the tuner didn't change the A/F. After installing the 52mm TB the idle was erratic and cam surge at low revs was worse. A tune by Jeff Creech smoothed it out and gained about 10 HP for me.
Old Jul 5, 2005 | 09:55 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
Theres a guy out in KS that does them. He hangs out on the CZ28.com board. he puts new bearings in them and all.
They require reprogramming definately if the car is a 94+ just to get the transmission back in line.. oR the best it can possibly be.
Old Jul 5, 2005 | 10:21 AM
Red Tornado's Avatar
Red Tornado
i'll also offer another source, although i don't know how useful it would be. i bought my 52mm used, it was a stock unit bored out and bearings, etc. all replaced.......work was done by Arizona Speed & Marine.....however I don't know what they charge for the job.
http://www.azspeed-marine.com/
To Why does no one port TBs?
