Cam Question
Old Jul 5, 2005 | 12:25 AM
89vettefromhell's Avatar
89vettefromhell
Default Cam Question
Whats the next step up from stock for an 89 L98 Vette... i just want something a lil more than stock nothing serious just put out a lil more power when i get the port job and true duals goin
Old Jul 5, 2005 | 12:48 AM
Red Tornado's Avatar
Red Tornado
the next step up, which would work in concert with an otherwise stock setup, is the Lingenfelter (LPE) 211 cam....p/n 74211, specs: duration 211/219, .499/.525 lift w/1.5 rr's, .530/.560 w/1.6 rr's, rpm range 1600-5200 rpms, 112 LSA.
this is a very good stock upgrade with very high lift given the duration, which is great for torque
Old Jul 5, 2005 | 12:49 AM
fnseeker's Avatar
fnseeker
Default Your next step
Don't miss the simplist step of all. Install a set of 1.6 roller rockers. This will give you more lift and duration out of the cam you have. You will notice the differance right away. Full roller rockers will give you a faster reving motor and a little more rpm range aswell as more power. Set you back around$200.00- $300.00 . If you install them yourself.
Old Jul 5, 2005 | 12:56 AM
Red Tornado
higher ratio rr's - by themselves with no other mods - from 1.5 to 1.6 MAY give 15chp.....hardly much for SOTP, which is what counts in every day driving.
Old Jul 5, 2005 | 01:08 AM
vader86's Avatar
vader86
211 is good, you could also try the TPiS ZZ9 cam.
Old Jul 5, 2005 | 03:33 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Either cam would be a fine choice.
If you are talking about porting the stock #113 heads, then adding an Accel base with AS&M LT runners would round out the package.
The only other thing you might do is to install a HyperTech coil/cap/rotor package with performance wires and open the plug gap to .045". This will assure a good charge burn at high rpm.
You will also need to raise your WOT shift points to around 6k RPM to take full advantage of the much improved breathing up top. B&M (from Summit) makes a nice Governor Recalibration kit for this purpose.
Old Jul 5, 2005 | 04:33 AM
hippy's Avatar
hippy
So you guys recommend doing a cam change when the guy asks for "nothing serious" and he is going to port his heads in the future?
Last I checked doing a cam basically involves removing the front of the motor, and the intake. I would call this a tad more involved then nothing serious. Since he plans to port his heads in the future wouldn't you think it wise that he pulls the front off and intake off once and takes the extra 2 hours to do the cam at that time?
Nothing serious to me would be underdrive pulleys, 1.6 rockers, bypass the coolant to the TB, set of big tube runners and of course headers.
Old Jul 5, 2005 | 09:55 AM
Red Tornado
we recommended a cam change because that was the subject of his post. the cams recommended are 1 full step up in duration from factory. we interpreted "nothing serious" to mean a cam that would not be radical and unfriendly for the street.
no need to get so sanctimonious. if you would read, you'd see
Old Jul 5, 2005 | 10:14 AM
carbster09's Avatar
carbster09
Default 383?
What about the above, basic build plus 383 stroker? My buddy is rebuilding his and I think a 383 kit is a good idea with a mild cam.
Thoughts?
I drive a 71 Ls-5, so I cannot help with anything other than the basics!
carbster09
Old Jul 5, 2005 | 12:10 PM
hippy's Avatar
hippy
OOPS my bad. I missed the title as being cam change. SHT. Well anyway I wouldn't do the cam change with nothing else as there are a lot of easier ways to gain the 20 hp than a cam change.
I put down 276 rwhp with stock heads and cam. So the next step doesn't have to be a cam.
Old Jul 5, 2005 | 12:13 PM
vader86's Avatar
vader86
Originally Posted by hippy
I don't recall cams being the subject of this post. Could you post where I missed cams as the subject as I thought I read the post correctly..
I guess you didnt see the title of this thread then did you.
Old Jul 5, 2005 | 12:18 PM
hippy's Avatar
hippy
I edited this post about 2 minutes after I posted. Damn you guys are fast.
Old Jul 7, 2005 | 12:03 AM
89vettefromhell
thanks for al the advice... i think im gonna go with what bradvette first suggested... thats not to big of a cam and i plan on throwing the 1.6s on there too...
Old Jul 7, 2005 | 12:20 AM
hippy's Avatar
hippy
Do you realize that with this cam and stock heads you will be putting springs in the heads? Also stock 113 heads stall at .500 lift. Anything over that lift is no benefit. With a stock 113 head you'd be better off cost wise and performance with a lift UNDER .470-.490 (no spring change) and a bit more duration. TPiS had the Super Profile cam that had the same lift as the stocker but around 10-12 more degrees duration at .050.
For the hp improvement you are looking for you can easily achieve this with stock heads and cam.
Old Jul 7, 2005 | 10:29 PM
89vettefromhell
well i already have new springs... and i checked the cam that they recommended and asked my guy at GM who says that cam will work with the stock head perfectly even with 1.6 rockers
To Cam Question
