Hotcam guys...
Old Jul 6, 2005 | 02:55 PM
JB666's Avatar
JB666
Default Hotcam guys...A/C problem at idle.
Since my engine's been done, when ever I turn on my AC, the idle surges way down, to the point that it SOUNDS like the engine's going to stall.
One person told me to adjust the set screw on the TB to allow more air in, but I would think that would raise the idle??
It was fine before - I added the Hotcam, 1.6RR's, LT4 Heads/Intake(ported) and a few other things. Any suggestions?
Old Jul 6, 2005 | 02:59 PM
STL94LT1's Avatar
STL94LT1
This thread may help.
http://forums.corvetteforum.com/show...92&forum_id=82
Old Jul 6, 2005 | 03:04 PM
JB666's Avatar
JB666
Thanks!
I subscribed to the thread, I'm curious to see where it goes.
I've talked to Bryan at PCMForless about it, not Alvin. He was the one who suggested the TB adjustment.
Old Jul 6, 2005 | 04:20 PM
99svrcpe's Avatar
99svrcpe
I have a similar problem with the a/c on my hot cam'd LT4, however mine only stalls or nearly stalls at idle when in open loop. Iac count's with a/c on : 109
Old Jul 6, 2005 | 04:41 PM
DVNCI's Avatar
DVNCI
Thanks!
That just seems like a hack to me - it needs to be done in the tune - if it is idling fine with A/C off but not on it's a software problem not mechanical it seems to me? (granted i ain't no expert either)
Old Jul 6, 2005 | 05:49 PM
boulderlt4's Avatar
boulderlt4
Mine did the same thing after I had the heads ported, and blah blah blah.
Took it in, he adjusted the screw, and it has been fine!
Old Jul 9, 2005 | 10:33 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
There is a parameter in the PROM for RPM added when the AC is engaged.
That seems to be the correct place tomake the 'adjustment'.
Old Jul 10, 2005 | 12:25 AM
VenkmanP's Avatar
VenkmanP
Old Jul 10, 2005 | 01:00 AM
Dan Parker '96's Avatar
Dan Parker '96
If you don't have the idle set a bit higher then the PCM will try to drive the IAC to compensate for the idle rpm. Unfortunately, the stepper motor is a bit slow and causes the engine to "hunt" quite badly.
The fix is to raise the idle (850-900rpm seems to work quite well) or you can slightly drill out the "straight through" plenum supply hole in the intake itself.
The IAC circuit in the throttle body directs air through ports drilled in the intake that terminate directly to each individual port. The "straight through" or "bypass" port directs air into the plenum itself. With the throttle body off, the flow path is obvious.
Drilling out the direct (to the plenum) port in small stages will allow a nice idle without having to "crack" the throttle blades.
I do recommend cranking up the idle slightly before modifying the IAC flow path. It may provide satisfactory results.
EDIT: If you are running an aftermarket throttle body then they have issues of their own. Typically, their idle ports (from the IAC) do not match well to the intake. Some massaging is needed. My comments apply to a stock style throttle body.
Old Jul 10, 2005 | 01:57 PM
Nathan Plemons's Avatar
Nathan Plemons
I know you said that you subscribed to the other thread but I thought I'd give you a bump and let you know that I've found my solution, I posted it in the other thread.
Old Jul 11, 2005 | 08:51 PM
JB666's Avatar
JB666
Excellent - I just read it - Thanks!
The car actually stalled today with the AC on , it's the first time that happened.
Old Jul 12, 2005 | 11:49 AM
JEFNLSA's Avatar
JEFNLSA
Wow, so I'm not alone w/ this. I have the same problem w/ my hotcammed/BBK'ed LT4. I'm going to get the "Tunercat" software and get this baby running right (never re-tuned since mods) but in the interim is it smart to try & make some adjustments w/ the TB screw (ie idle ajustment)?
Mine doesn't stall but definitely drops down significantly (when I turn on the a/c) in "open loop" but in "closed loop" it seems to find the idle.
I just don't like the way the motor "feels" when I have the a/c on (open or closed loop). A/C off motor runs awesome.
A/C on or off, you can't tell the difference in our BMW but the Vette (on the other hand) seems to really feel the power robbing effects of the a/c.
What's up w/ that?
To Hotcam guys...
