turn signal pivot assembly replacement 87
Old Jul 7, 2005 | 08:24 AM
gumba87's Avatar
gumba87
6th Gear
Default turn signal pivot assembly replacement 87
Have an 87, broke the turn signal arm. looks like plastic assembly inside the steering column cracked. Do I need to disassemble whole column, or is there an easy fix. Thanks in advance
Old Jul 12, 2005 | 12:28 PM
gumba87's Avatar
gumba87
6th Gear
Took off steering wheel and turn signal arm was not broken. There is a phillips head screw that holds the lever to the turn signal assembly- it was loose-tightened- back in business.
Old Jul 12, 2005 | 12:33 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
gotta love an easy, cheap fix
To turn signal pivot assembly replacement 87
