96 Auto Trans Overheating
Old Jul 7, 2005 | 05:04 PM
96_LT1's Avatar
96_LT1
Default 96 Auto Trans Overheating
Hi, my 96 trans is overheating, the warning came up, I checked the temp it was at high, I forgot the actual reading though, I pulled over for a while to let it cool down then drove back home.
Any ideas what could be causing this? Anybody out there experienced similar problems?
Old Jul 7, 2005 | 05:29 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
What kind of shape is your fluid in? I'd check the lines and cooler for blockage and seriously consider a flush and upgrade to synthetic fluid as well as an additional cooler.
Old Jul 7, 2005 | 07:48 PM
rsafier's Avatar
rsafier
If your warning came up then you definately better have someone look at it. And change the fluid for sure. The warning is something like 300F+! I killed a tranny by getting into the 260s too many times.
Assuming nothing bad is going on, probably should consider an extra cooler. I went with a giant B&M stacked-plate cooler and now never see temps above 180F.
Old Jul 7, 2005 | 08:57 PM
96_LT1's Avatar
96_LT1
This is worrying me now!
Up for any other suggestions
Old Jul 7, 2005 | 09:07 PM
RadPolo96's Avatar
RadPolo96
I put a B&M Tranny cooler on mine after I installed a higher stall converter. It definately helped alot and it wasnt to $.
Old Jul 8, 2005 | 08:13 AM
runner140*'s Avatar
runner140*
Last year I had my 1996 A4, flushed and refilled with a synthetic and now averages 197.
Old Jul 8, 2005 | 07:47 PM
96_LT1's Avatar
96_LT1
Ok heres a bit of info that could help you guys. The car hasnt been used for around 18 months+, and when in neutral or park the revs stay at about 1500rpm, when in gear they drop but not by much say about to 1200rpm or so. So whenever I take my foot off the brake the wants to launch itself uderstandably. Could this be another reason as to why its overheating the trans?
Im not 100% sure,but I think the trans temp is OK when driving, and climbs during traffic.
The car is completly stock, exterior, interior, mchanically etc.
Old Jul 8, 2005 | 10:33 PM
johnzz4's Avatar
johnzz4
Yes, the high idle will absolutely cause higher tranny temps. You need to determine the cause of your high idle.
Old Jul 9, 2005 | 01:56 PM
Hotred94's Avatar
Hotred94
Its not normal for the trans to overheat in regular driving. Get on it right away or your trans won't last long.
Old Jul 9, 2005 | 02:01 PM
Matt O's Avatar
Matt O
The high idle is the problem. Get that fixed and change the tranny oil and filter...
Old Jul 26, 2005 | 09:47 PM
96_LT1's Avatar
96_LT1
Well now im faced with a problem?
I have no idea what is causing the high idle?
Where can i turn the revs down from, for now so that I can get the the car to my mech?
Old Jul 26, 2005 | 10:09 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
Check out this forum thread, may be of help
http://forums.corvetteforum.com/show...le&forum_id=48
Old Jul 27, 2005 | 07:54 AM
runner140*'s Avatar
runner140*
The first place to start is to check the fluid. It its dark, smells burnt and hasn't been changed in 50000 miles, change the fluid and do a complete flush. Then check the temps after. Its a cheap first place to start.
Old Jul 27, 2005 | 03:33 PM
chevyc4's Avatar
chevyc4
Your high idle could be due to a vacuum leak somewhere. If not then I am 99% sure it is your IAC (they tend to get gummed up with age).
Old Jul 28, 2005 | 06:30 AM
96_LT1's Avatar
96_LT1
Sorry to be rude guys, I never thanked everyone for their help, im just really worried!
Let me give you guys a bit of an insight into the high idle problem first.
When you first start the car and its cold, it idles fine, about 900-1000rpm I think, then give it a few mins, and it starts to warm up and the revs climb.
Where is the IAC? Any pics?
Thanks guys!
Old Jul 28, 2005 | 10:19 AM
96_LT1's Avatar
96_LT1
UPski
Old Jul 28, 2005 | 04:54 PM
96_LT1's Avatar
96_LT1
up!
Old Jul 29, 2005 | 04:55 AM
skeet's Avatar
skeet
Evan, where are you. This member is going to market a cooler, bracket that mounts on the PS cooler and all hoses.
Old Jul 29, 2005 | 07:35 AM
Atok's Avatar
Atok
This happened to my wife's car. It's not a Vette but maybe your problem is similar. All it was with hers was a bad connection on the sending unit.
To 96 Auto Trans Overheating
