Reverse Switch Installation
Old Jul 8, 2005 | 03:18 PM
Joe N's Avatar
Joe N
Cruising
Default Reverse Switch Installation
Folks, I have a 90 convertible and I am trying to install a new reverse switch on my 6 speed transmission. I had no problem getting the old one out, but have been striking out getting the new switch threaded back into the transmission. I have tried to search the forums, I keep getting a error message. Any suggestions would be appreciated. Thanks. Joe
Old Jul 8, 2005 | 06:08 PM
bogus's Avatar
bogus
any time you are threading something in where you can be a bit off, I suggest taking it slow and easy.
Also, spray some light oil (PB Blaster or WD40) on the threads, that will help ease it in better.
Old Jul 8, 2005 | 07:27 PM
LPDesRoche's Avatar
LPDesRoche
I have changed a few of these and like bogus said there is really no trick, it's just like installing a bolt. You may be off a bit in your angle. Only tip I can offer is try turning it counter-clockwise a bit first until you feel it click so to speak and then resume clockwise turning. Generally works for me when I am trying to tighten something by hand in a small tight spot.
Old Jul 9, 2005 | 06:16 AM
Joe N's Avatar
Joe N
Cruising
Thanks for the suggestions. I am going to give it another try today. The slave cylinder and the hydraulic line have made it a difficult spot to reach. Joe
Old Jul 9, 2005 | 09:20 AM
mik's Avatar
mik
Default Back-up Switch
I just did mine. The trick for me was to loosen the slave cylinder. I loosened both nuts on the cylinder and removed the one that let me tilt the cylinder out of the way. With the extra room, getting the switch in was much easier.
Old Jul 9, 2005 | 01:19 PM
Fast Eddiz's Avatar
Fast Eddiz
My back-up lights are not coming on so I'm assuming the switch is bad(the bulbs are OK). How do you get to the switch? Can it be worked on by removing the console or from underneath? Ed
Old Jul 9, 2005 | 02:59 PM
bogus's Avatar
bogus
you have to get at it from underneath.
To Reverse Switch Installation
