rpm in $8D
my problem is, i have an L98 and most of the rpm numbers in the bin stop at 5600rpm
i want to hang in another engine that revs to 6500..
how can this tables be extended?
CATS TDF editor??
best regards
http://forums.corvetteforum.com/show...m_id=82&arch=1
A simple change to RPM-only tables is found here:
http://www.moates.net/files/5)%20Sou...acks/8d_ve.txt
http://www.moates.net/files/5)%20Sou...acks/8d_ve.zip
A more elaborate change is described here:
http://www.thirdgen.org/techbb2/show...hreadid=296415
Check the TGO board for more ideas, IF you are comfortable changing program code.
