Valve spring compressor: Any Recommendations?
Old Jul 9, 2005 | 10:38 AM
tequilaboy's Avatar
tequilaboy
Default Valve spring compressor: Any Recommendations?
I'm planning to install LT4 springs/retainers on my L98 with the heads on, motor in the car, in preparation for a future cam change...
Will a $25 Manley pry-bar type do the job? It looks like there will be enough clearance. Also considering the Crane Cams valve spring compressor that looks like it can do 2 valves at once, but is a little pricey at around $100 or so.
Any info on what works or what doesn't work will be appreciated.
Old Jul 9, 2005 | 12:12 PM
96redvette's Avatar
96redvette
I'll be doing this very soon as well, but with the heads off, curious to see some answers
Old Jul 9, 2005 | 12:23 PM
Ramanstud's Avatar
Ramanstud
I just did this yesterday on my L98-ish (haha) motor. You may want to shell out the $15 for the "c-clamp" type compressor because space will be at a premium while the heads are in the car. A couple of tips off the top of my head:
*I hope you have an air compressor and appropriate adaptors to pump the cylinders with air (sears has everything you'll need). You'll want to put the cylinder you're working on at TDC just in case you lose a valve - it may save your butt or it may not.
*Be sure to rap the top of the valve spring lock/retainer assembly with a socket to jar the locks loose BEFORE you attempt to compress and remove the stock springs.
*Use a large screwdriver to work the valve seals off if you're replacing the cups. I had viton-type seals that are very durable - you may want to have extras in case you tear them up while removing them.
*have a magnetic wand handy - works great for getting the valve retainers out initially.
Be patient and take breaks!
Old Jul 9, 2005 | 12:27 PM
STL94LT1's Avatar
STL94LT1
Don't know about the L98, but this one worked really well on myLT1. SUM-906784
http://store.summitracing.com/defaul....asp&x=35&y=10
Old Jul 9, 2005 | 01:19 PM
Hotred94's Avatar
Hotred94
Compressed air adapter for the spark plug hole, and the bar type spring compressor work great. If your practiced, you can change all eight cylinders in less than an hour.
To Valve spring compressor: Any Recommendations?
