differential plug size 3/8...
Old Jul 9, 2005 | 02:19 PM
rsrandy's Avatar
rsrandy
Default differential plug size 3/8...
Hi guys,
Just did a differnetial fluid change on my 1992 6-speed. I had read several places that the a 17 mm allen wrench was needed to fit the drain/fill plug. I finally found one at tool store (I knew I didn't have anything that big at home). Well the 17 mm did not fit my car, it was way too big. I used a 3/8 allen wrench, fit perfectly. I don't know if mine was an odd size but I did read a post up here that said he used a 3/8 also. I bought amsoil synthetic (two quarts) and two bottles (4 oz each) of their slip lock additive. I also bought a small hand pump for 11.00.
Jacked up the car, sucked out all the old fluid (I measured about 1.3 quarts. Pumped in all my fluids and will drive it later today to see if it fixed the problem I was having.
So...keep a 3/8 allen handy, if yours is like mine..
rsrandy
Old Jul 9, 2005 | 02:39 PM
rws.1's Avatar
rws.1
Yup! Mine is also a 3/8. only issue was that i could not fit the Allen key between the housing and the rest of the goodies under the car. I needed to by a 3/8 hex drive for my ratchet.
Old Jul 9, 2005 | 02:56 PM
STL94LT1's Avatar
STL94LT1
The 17mm is for the ZF6's drain/fill plugs.
Old Jul 9, 2005 | 02:58 PM
bogus's Avatar
bogus
I think you will find that the drain plug is actually 10mm.
I was unable to fit a 3/8" allen into the plug on a D36. I mean, it sorta fit, but man it was tight. And I cleaned it out... even if I didn't the metal was tight, not debris.
Old Jul 9, 2005 | 04:57 PM
Morley's Avatar
Morley
3/8 is smaller than 10 mm, should have been a sloppy fit.
Old Jul 9, 2005 | 05:55 PM
bogus's Avatar
bogus
hm... I will have to recheck the tool I used.
To differential plug size 3/8...
