re-seting "check engine light"
Old Jul 10, 2005 | 12:55 PM
takovr's Avatar
takovr
Default re-seting "check engine light"
I took off my MAS and now my check engine light stays on is there a way to re-set it so it dosen't stay on?
Old Jul 10, 2005 | 02:08 PM
sniperdiver37's Avatar
sniperdiver37
If your talking about resetting the ECM..... to clear codes.......
with the key OFF
disconnect the neg (-) power to the battery for about 30 seconds.
or with the key OFF
pull the ECM fuse in the fuse box for 30 sec. That should do it.
If your talking about the fact that you have totaly removed your MAS as some kind of Mod then you will need to just bypass it, pull the CEL bulb, or just live with it.
Each time you fix something that goes through the ECM you should clear and check it to see if you fixed it. Replacing parts and not clearing codes will get $$$$$$ Jeff
Old Jul 10, 2005 | 02:11 PM
takovr's Avatar
takovr
Default I just took it off to clean it
I just took off my mas to clean it, put it back on now my check egine light stays on I have a 86 vette
Old Jul 10, 2005 | 02:13 PM
sniperdiver37
Make SURE it is connected correctly. and reset the ECM.
Old Jul 11, 2005 | 02:11 AM
PierEagle's Avatar
PierEagle
Follow Sniper's advice in both posts. After you disconect bat and reset, if SES comes on again, pull code. Could be MAF, relay(s), or another problem that coincidently came up at same time you were working on MAF.
To re-seting "check engine light"
