1989 heads
Old Jul 10, 2005 | 01:58 PM
c3-shark's Avatar
c3-shark
Default 1989 heads
Can a set of aluminum heads from a 1989 be machined to fit 1985 intakes,, I want to put these 89 heads on my 85, is there an reletively easy way to make this work?
Old Jul 10, 2005 | 02:02 PM
Pete K's Avatar
Pete K
I think it will bolt on without issue. The vette stuff did not use the newer bolt angle on the center 2 bolts. You will lose egr though. 89 heads get egr from the pass side exhaust manifold. 85 gets it from the egr port in the head.
Old Jul 14, 2005 | 03:39 PM
c3-shark's Avatar
c3-shark
they dont seem to fit. the 85 has perimiter bolted valve covers, while the 89 uses center bolt style.
Old Jul 14, 2005 | 04:01 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Of course you will need to install the center bolt valve covers; try Contemporary Corvette (link on my site) for a used set.
Old Jul 14, 2005 | 04:08 PM
c3-shark's Avatar
c3-shark
the 85 intakes will not bolt on to the 89 heads, i have heard that Scoggen-dickie makes an intake that will fit the 89 heads to the 85 parts, but i dont know how to reach them.
Old Jul 14, 2005 | 05:32 PM
Davemc1963-87conv's Avatar
Davemc1963-87conv
c3-shark.
The 85 intake should bolt straight to the 89 heads, they (Y-bodies) use the traditional sbc intake pattern. (obviously as Pete K wrote, they wont accomodate your internal egr system, so you may have to get a custom prom with egr delete. There are several ways around this I believe) If they don't bolt up, then you may have possibly an F-body intake where the centre intake bolts are at a different angle (but can be made to fit) or a previous owner has fitted vortec heads and a 'scoggin-dickey' intake which won't fit! If you have vortecs, they flow better than 113 heads anyway in standard form. You can get adapters to convert centre bolt valve covers to perimeter type, but by the time your finished it is cheaper to just buy some centre bolt ones. While I am writing this, I realise that you mentioned/implied that you had perimeter bolt valve covers. That sort of rules out you having vortecs anyway I suppose.
Old Jul 14, 2005 | 05:44 PM
hz900's Avatar
hz900
The intake will fit, the bolt holes are at the wrong angle though, you can have a machine shop fix this issue for you though with no problems. You will need a new set of valve covers with center bolt holes. You could always hop on ebay and pick up a later model intake manifold for very cheap as they are not very desired. I sold my hole tpi intake of my '90 for like $120 (plenum, runners, manifold).
Old Jul 14, 2005 | 08:46 PM
CFI-EFI's Avatar
CFI-EFI
You should have read what was written above. The Corvette L98 never had but one intake manifold bolt pattern. There are no different angles to be fixed.
RACE ON!!!
Old Jul 15, 2005 | 12:58 PM
1986Z51's Avatar
1986Z51
Might also want to consider the change in CR going from 76cc to 58cc chamber heads. If 76cc heads give 9:1, 58cc would get over 10.5:1 assuming CR changes 1 point for every 10cc. Aluminum tolerates more compression than iron before preignition becomes a problem however. I've considered this upgrade several times but am unsure about the preiginition. LTx motors run higher compression but they have aluminum heads and reverse flow cooling.
Old Jul 15, 2005 | 02:12 PM
65Z01's Avatar
65Z01
Good point; if you are not going to run external EGR then a low temp T-stat will help reduce any ping tendencies.
Old Jul 17, 2005 | 11:21 PM
JETSET's Avatar
JETSET
Default Sb
The small block is the same bolt pattern
You may need to use your shorter push rods because you don't have a roller cam. If you are going to a larger CC head you will lose tons of power. If you cut the heads to raise the compression you need to cut the intake side to. But then you get into valve angle issues.
I run an 87 with aluminum heads
Manley flat tops forged pistons with two valve notches
4 lefts and 4 rights
I run them at zero deck height and 58 CC heads
plus a thin graphite head gasket
10.75 to 1 compression ratio
The horsepower this made was enourmous from the stock cast dished pistons.
i have a chip
528 lift SLP roller cam
ported heads
pro flow cut back sodium filled SS valves
total seal rings
the lower end was balanced blueprinted and aligned
no problems with detonation and it gets 28 - 30 mpg on the highway
Better milage than new
only 10 -15 in the city though
Maybe because i am kicking it down all the time.
To 1989 heads
