Gas cap WOOOSH...
Old Jul 11, 2005 | 01:01 AM
johnzz4's Avatar
johnzz4
Default Gas cap WOOOSH...
It was the same on my former '89 corvette, so I never thought much of it. One of the other threads mentioned replacing a vent valve near the charcoal canister and getting rid of the WOOSH. Should I be concerned?? Is this normal???
Old Jul 11, 2005 | 01:06 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It won't hurt anything. Worst that you'll get is gas fumes under the hood on a hot day. Most people think that's a bad thing.
Old Jul 11, 2005 | 01:08 AM
artvette's Avatar
artvette
I'd say it was normal. If it's hot out and the tank is 1/4 full or so, you will get more. A lot of vehicles tell you to open the cap slowly until the hissing stops and it's normal for them as well.
Old Jul 11, 2005 | 01:14 AM
CentralCoaster
It's only normal when the car is left sitting and the temperature changes.
When you drive, the vapor purge system dumpes those fumes into the intake. It's to prevent them from escaping to atmosphere. Smog deal.
Old Jul 11, 2005 | 01:06 PM
SunCr's Avatar
SunCr
If it's purging at the tank valve in the engine compartment, you need to replace that valve. It's there to keep the fumes (and the whoosh so to speak) in the tank until vacuum is applied which allows the fumes to flow into the canister and then into the engine upon certain throttle conditions. Gas fumes in the engine compartment are never good.
Old Jul 11, 2005 | 01:17 PM
STL94LT1's Avatar
STL94LT1
My gas cap has done the whooosh, since the car was new.
Old Jul 11, 2005 | 08:05 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
There are two valves on the charcoal canister, purge valve & control valve. I had the same issue with fumes, replaced them both &
problem cleared.
Old Jul 12, 2005 | 09:28 AM
rws.1's Avatar
rws.1
It has been unusually hot here in Michigan this summer. This weekend it was over 90 and my tank was down to about 1/8. The woosh was very noticeable on re-fueling....
It usually isn't that noticeable, but a low fuesl level combined with sitting in the hot sun vaporizes the gas and increases pressure
Old Jul 12, 2005 | 10:30 AM
CentralCoaster
A low tank means more vapors, means more to expand in the heat. Remeber, the empty part of your tank is all fumes.
To Gas cap WOOOSH...
