Heater doesnt work...not like it matters...
Old Jul 11, 2005 | 02:07 AM
philly1919d's Avatar
philly1919d
Default Heater doesnt work...not like it matters...
Well im going through my entire car and trying to fix anything that is broken. One of these such things is the heater. I have a 92. Even when i push the temp up all the way to 90 degrees it doesnt heat up at all. Any thoughts?
Old Jul 11, 2005 | 02:26 AM
hngacurv's Avatar
hngacurv
Is the heater core getting coolant flowing through it? I used to shut the valve that lets it flow through in the summer.
Old Jul 11, 2005 | 04:43 AM
pablocruise's Avatar
pablocruise
Hi philly,
one thing to check is the vacuum supply to the HVAC controller. The system needs vacuum to work. Vac is supplied from the engine. Look for a leak on the tubing or on a fitting on the line that feeds the vac to the controller. It should be near the back of the intake plenum(engine).
You may want to flush the heater core and verify it's not clogged/and allowing hot coolant to flow thru it and not just over it.
Be very gentle handling those core hoses/pipes. At their age by now, they are weak and you don't want to break a heater core pipe. It would be a major PITA to replace the heater core.
Let us know what you find.
Old Jul 11, 2005 | 02:22 PM
Fast Eddiz's Avatar
Fast Eddiz
Sounds like we're going thru the same experience. I'd like to restore my 92 to near original condition. When I first got it I couldn't get any heat or defrost. After doing some exploratory surgery I found the previous owner had bypassed the heater core- for good reason- it leaked! Take a look under your surge tank to see if the core has been stubbed off. Best of luck!
Old Jul 11, 2005 | 02:37 PM
Lichen's Avatar
Lichen
In my '93, it was the heater control valve. Warranty covered it so I have no idea how hard it is to replace.
SunCr's Avatar
SunCr
Vacuum has little to do with whether or not you get heat. The door that controls heating/cooling is either actuated by an electric motor (electronic air) or a cable (Manual Air). To see if the door is moving remove the Blower Module (Electronic Air) or Resistor Pod (Manual Air) from the Evaporator Case and look inside. Then, as someone operates the controls, make sure the door moves from heat to cool and cool to heat. If all is well, the heater core is probably plugged up. If it is, the rest of the cooling system may be plugged up too, so it's good idea to fix it and make sure the system is clean. You can try flushing the core with water from a garden hose or by using compressed air. If neither works, you'll need a new core.
Old Jul 11, 2005 | 04:16 PM
mikey whipreck's Avatar
mikey whipreck
so lets say the door isn't moving on a manual air '85...
what would the fix involve?
Old Jul 11, 2005 | 05:03 PM
SunCr's Avatar
SunCr
If it's electronic air, usually the plastic linkage between the motor and the door is broken. Easiest to access with the ECM removed. If it's manual air, it's controlled by a cable from the dash to the heater plenum and generally the cable has broken, but I've seen some GM dash units (on other models) broken behind the **** or push bar.
Old Jul 23, 2005 | 08:28 AM
dortoh's Avatar
dortoh
2nd Gear
Default 1989 C4 L98 HVAC Stuck in Heat only mode
Anyone know how to troubleshoot the air mix motor on a 1989 C4 with electronic AC control. I can see the air mix motor and control rod when I look up under the RHS of the dash and the rod does not move with I push the Auto AC mode. I do not get any error codes on the control module. The stock radio was missing when I brought the car and there are some cut wires and disconnected connectors. Anyone have the wiring diagram from the control module to the air mix motor? Thanks
To Heater doesnt work...not like it matters...
