early c4 wheel question
Old Jul 11, 2005 | 11:27 AM
mikey whipreck's Avatar
mikey whipreck
Default early c4 wheel question
I am shopping for tires for my 1985.
On the back I have the z51 model rims, which are 16 x 9.5"
The stock size tire for that rim is a 255/50/16... but that seems too small for a 9.5 rim.
I look at tire rack and the tires I want, say the acceptable rim with is 7" to 9" for a 255/50/16 (yokohama's).
So what's up?
What size can I use that might be more appropriate for a 16x9.5?
what effect would a wider tire have?
Old Jul 11, 2005 | 11:47 AM
CFI-EFI's Avatar
CFI-EFI
Does anyone make a wider tire in a 50 aspect ratio? The car came with 255/50/16's front and rear on 8 1/2" front and 9 1/2" rear wheels. I'd say wider tires would be fine, if you can locate any. I just had a pair of 245/50/16's mounted on 9 1/2" wheels. Now THEY look silly. I had thought they were going onto the 8 1/2" wheels, until it was too late.
RACE ON!!!
Old Jul 11, 2005 | 12:10 PM
mikey whipreck
I can't believe you fit a 245 on a 9.5" rim.
My reason to avoid wider tires if possible is that I dont want to mess up the speedo.
But do you think a 265 (or even 275) tire would be okay?
I looked a little more and I found a set of Sumitomo's that say the acceptable rim width is 10" - the tread width on those tires is a lot wider (almost an inch wider then the yokohama and bfg's I was looking at).
Old Jul 11, 2005 | 12:17 PM
scorp508's Avatar
scorp508
That is the correct size. I wouldn't go wider in that aspect ratio. Actually I don't know if I ever saw a wider one.
Old Jul 11, 2005 | 12:43 PM
Stefan Nord's Avatar
Stefan Nord
275-285 no more
C4 17x9,5 wheels has 275 original...so it´s perfect with 275
Old Jul 12, 2005 | 01:07 AM
Calsquid's Avatar
Calsquid
If you go with 275's you will need to go with a 45 aspect ratio. try fooling around with this:
http://www.miatanet.com/garage/tirecalc.html
Old Jul 12, 2005 | 06:17 AM
DanZ51's Avatar
DanZ51
315/40-16 XGTV Michelins Sports (old school) hanging on the back of my '86. This might be a hard size to find, as I've only seen them from Michelin and only shoehorned on the back of someones Vette.
Old Jul 12, 2005 | 08:42 AM
mikey whipreck
That's a cool link, thanks
Old Jul 12, 2005 | 08:52 AM
loiq's Avatar
loiq
I have 255/50/16s on my 87 with Z51 rims. They look fine.
Old Jul 12, 2005 | 11:35 AM
CFI-EFI's Avatar
CFI-EFI
Me neither. By the time I realized what was happening, it was too late to do anything about it. What surprised me, was they had no problems getting the beads to seat.
A minor width difference, alone should have little effect on the speedo. Personally, I have never seen or heard of anything wider than a 255. If you can get 265's or 275's, I'd go for them.
We're talking 16" wheels, here.
That's not too surprising, since it is the stock size for that year.
RACE ON!!!
Old Jul 12, 2005 | 02:37 PM
kkonen's Avatar
kkonen
Non z51 used 255/50 16s. I think 275/16 was stock on Z51, but I don't remember the aspect ratio. I know stock tires were Goodyear. I raced on some 265 kumho victorracers once that fit really well.
Old Jul 12, 2005 | 03:57 PM
MrNuke's Avatar
MrNuke
Nope..
Non Z51's got the 8.5" 16" wheels, which from Gm came with 255/50 16's..
Z51's got the 9.5" wheels all around but the same tire width..Go figure..
I have been through 4 sets of wheels with my vette, and to whoever that is running 315/40's on his 9.5" 17" wheels, they shouldn't be. For 9.5" wheels they are way too thick and will not contact the ground perfectly.
Old Jul 12, 2005 | 06:32 PM
CFI-EFI's Avatar
CFI-EFI
NOPE! All 1984 through 1987's came with P255/50R/16 tires from the factory, regardless of the wheel width. 1988 was the first year 17" wheels came from the factory, although 16" wheels remained available through 1989. The only 16" tire Chevy put on the C4, of any year, with any options, was a P255/50R/16.
RACE ON!!!
Old Jul 12, 2005 | 11:12 PM
DanZ51's Avatar
DanZ51
WELL, the Michelin listed the recommended rim widths from 9" to 11.5" for the (out of production) 315 XGT. That's on a 16" rim (not 17"), a little more side wall height to handle the bulge.
No, it's not optimum for best lateral handling, but it definately helps the 0-60 times. And it will pacify my urge for new rolling stock til next year.
Old Jul 12, 2005 | 11:29 PM
BLUE BETTY's Avatar
BLUE BETTY
dunlop sp sport 8000 255/50 zr16 recommended rim with up to 10 "
john
Old Jul 13, 2005 | 11:56 AM
artvette's Avatar
artvette
I have a set of Michelin Sport XGT Plus tires to sell. (2) 315/40ZR16 and(2) 255/45ZR16 that are mint with maybe 8500 miles on them. I had the 315's on the 9.5" rims and never had any issues with them. I just changed rim size and tires to allow for bigger brakes.
http://forums.corvetteforum.com/show...1133867&page=2
To early c4 wheel question
