86 Dies with AC Running (sometimes)
Old Jul 12, 2005 | 12:31 PM
geezel's Avatar
geezel
Default 86 Dies with AC Running (sometimes)
Just finished my top end build (heads, cam, intake, etc). With the AC on, the engine will occasionally die during idle. Custom chip idle set for 750 RPM & idles fine with no AC. Is this strictly an IAC issue? Do I need to bump the idle speed or check something else?
Old Jul 12, 2005 | 01:07 PM
Morley's Avatar
Morley
If the IAC and passages are clean you need more IAC counts added (in the chip) for A/C operation "Idle speed adder, A/C enabled" is the table you are looking for.
