Does anyone know how much of the C4's underbody is metal? I know the frame is, but from looking at the GM diagrams, it seems that there are metal reinforcements supporting the main body. Is this right?
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Originally Posted by grandspt
So was anything glued to the frame? Or was it the upper rear qtr. panels?
Having just taken my front end, forward of the doors, apart, I can testify that from the doors forward everything is bolt on and looking at the rear, I believe the upper quarter panels may be bonded, but the lower are bolt on. The rear bumber assy is definitely a bolt on
This sort of supports what the book says
There is a lot of metal in our cars, only the body panels and the front and rear springs are fiberglass
Cruise-In I Veteran
Cruise-In V Veteran
Originally Posted by 4bblC4
is any of it steel? or all aluminum?
Most everything is galvanized and painted steel. GM and i sort of believe it says the C4 is the first truly rust proof Vette
The quality of the galvanizing and the painting seem very good and there have been few reports, if any of chassis rusting out. This was a problem on C1,2,3
The rear bumber frame assy which bolts to the main frame assy was steel until sometime in 1988 when it was switched to aluminum.
My late 1988 is aluminum, but 88's were supposed to be steel
If you are curious, a magnet will answer your questions. Neither aluminum or fiberglass will attract the magnet.
The firewall and forward section of the floor are fibreglass and are bonded to the frame and to each other.
The rear "tub" is fibreglass and is also bonded to the frame. The upper quarter panels are bonded to the frame and also to the rear tub. The exterior roof halo cover is also bonded to the frame. Also, the lower "dog legs" are fibreglass and are bonded to the frame.
The rear section of the floorpan is steel--the part that the seats sit on--and the vertical wall directly behind the seats is also steel.
One thing of interest I found is that different adhesives were used for bonding FG to FG and FG to Steel.
Linn
edit: Oh yeah, the sill covers are also bonded to the frame.
GM service manuals for C4s have line drawings in the back showing the basic frame of these cars, both coupe and vert. The frames are steel, all else is FG. Yea-get a magnet and go exploring!
Linn
Thanks for the info. I knew I read somewhere that bonding was used on our cars.
I recently completely disassembled an '86 down to the frame. As Black 'n Blue mentions alot of fiberglass body parts unbolt such as the doors, fenders, hood, bumpers, etc. The rest are bonded to the birdcage, sills and rear tub. What's interesting about the rear tub is that it sits on the rear part of the frame on pads. It's not directly bonded to the frame. However the attachment points where it is bonded and riveted is the vertical and horizontal areas directly behind the seats and at the door jam pillars where the halo ends. The rear fenders are bonded to the rear top surround and the rear top surround is bonded to the tub. The rear fenders attach to the rear bumper and inner fenders, which are attached to the frame with screws and braces. It's a very elaborate method of attaching the body to the frame. A real pain to disassemble. Glue and rivets. I have some pics. I'll post them when I find them.
Art
Cruise-In I Veteran
Cruise-In V Veteran
Originally Posted by MrRenoman
I recently completely disassembled an '86 down to the frame. As Black 'n Blue mentions alot of fiberglass body parts which don't unbolt such as the doors, fenders, hood, bumpers, etc. are bonded to the birdcage and rear tub. {SNIP}
Art
Don't mean to quibble, but on my 88 vert, doors, fenders, hood and bumbers actually un bolt!
So do rear bumper and lower rear quarter panelas, wheel wells, etc
I have actually physically unbolted these parts from my car. I am amazed, or rather was amazed when I first did this, that the darn thing would stay together at 140 mph
Is my car unusual?
I know a lot of adhesives were used in C5 and C6and i am sure you are right about "tubs", but at least on mine, everything else un bolts...I have never tried the upper rear quarter panels, so I can't say for sure
Yeah, those rivets really suck. I'm guessing they were only used to hold the bonded pieces together until the adhesive cured, since using clamps on an assembly line probably wouldn't be practical.
Art
Please, post these pics!
I'm suspecting that the "C4 ghost driver lean" is related to the wear that can be developped to the pads where the frame is bonded to the frame.
-Beppe-
Wow! Thanks for all the answers. I should have been more descriptive with my question. I had no doubts that the frame was metal. My concern is the upper main body shell. On a recent tv show, a Corvette expert talked about the tendency of fibergalss to weaken over time causing cracks and such. He was dealing with a '66 I believe. My C4 developed a crack in the quarter panel behind the driver's door, right at the front-bottom corner of the rear glass. It's about an inch and half long, and has not gotten any longer or wider in the past 5 years when it first appeared. I have patched it with some fiberglass filler, but it came right back. I was wondering if this could be that fibergalss fatigue, or if there were a metal substructure behind it, in which case that would be unlikely. It's the only spot on the car that any crack has developed. The rest of the car is perfect, so I'm kind of concerned as to what the cause is.
