I have to get my C4 smogged this month. It will be on the ragged edge. It's an 11/1 400 in with a solid roller on 112 lobe centers. Lobes are 268 seat and 230 @ .050. It runs great. I'll take it down once I reinstall all of the stock exhaust. I have to use a test only station too.
I do my own tuning and wondered if I should retard the timing a bit and also if alcohol at 15% in the fuel would be a big help.
Another pain for me will be getting my stock centerbolt valvecovers to fit with the wide body rockers. They will be ground pretty thin. Any suggestions there?
I have to get my C4 smogged this month. It will be on the ragged edge. It's an 11/1 400 in with a solid roller on 112 lobe centers. Lobes are 268 seat and 230 @ .050. It runs great. I'll take it down once I reinstall all of the stock exhaust. I have to use a test only station too. I do my own tuning and wondered if I should retard the timing a bit and also if alcohol at 15% in the fuel would be a big help. Another pain for me will be getting my stock centerbolt valvecovers to fit with the wide body rockers. They will be ground pretty thin. Any suggestions there?
I think you're hoping for miracles to get an 11:1 400 with a solid roller with 230º duration to pass smog. I would DEFINATELY try some alky and retard the timing (to keep cylinder temps down as much as possible).
With the centerbolt valvecovers I doubt you'll be able to fit standard rocker arms...
Good luck though, let us know the results.
Don't go down too much on the timing. If it isn't within a couple degrees of stock they will fail you. I had one car fail because the idle was set too high and they wanted to charge me $25 to turn a screw. You can always use that 'Pass or don't pay' gas addative you get from the parts stores.
I have a friend that ran a solid roller with 268 seat duration and tighter lobe centers and was able to pass with a 350 without running alcohol. He was running a DFI system and doesn't remember how much he retarded timing. From his experience I think I have a good chance, especially if I use alcohol as well.
As I understand, the new tests on the rollers are between 2000 and 3000 rpm with a light to medium load. Any thoughts on where in the timing curve and how high a vacuum level I should target for retarding the timing? Or is it easier to just reduce the entire table? Any thoughts on how much?
Thought I'd share what I learned. Everything passed with lots of margin except the NO. That was on the edge but it passed too. So it can be done with a short seat duration solid cam and a wide lobe center as long as you pull a little bit of timing out.
