codes 32, 34 and 43
Old Jul 13, 2005 | 11:30 AM
thrills's Avatar
thrills
Moderatrix
Cruise-In IV Veteran
Default codes 32, 34 and 43
Hey ya'll, I cant seem to find my shop manual and looking up the codes on the general net seems like trying to find a needle in a haystack anymore. If anyone has a service manual can you lemme know what these are for? TY in advance
Old Jul 13, 2005 | 11:36 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
32==EGR failure
34==MAF or MAP too low
43==knock sensor
Fix the EGR problem first; there is a method on my site.
If your car has a MAF (what year Vette??) the problem may be in the power relay.
With the first two problems fixed the knock sensor problem may vanish.
Old Jul 13, 2005 | 11:54 AM
thrills's Avatar
thrills
Moderatrix
85 corvette, ill add my sig. TY, I guess Ill just have to take it to the mechanic again. Great guy I can definatly trust him. I just like to have an idea of whats wrong with it before it goes in. TY again.
Old Jul 13, 2005 | 12:01 PM
bogus's Avatar
bogus
sorry, most of us have sigs off. Troy kinda asked everyone to do it to save bandwidth....
as for the EGR:
1) Does the code appear immediately? If so, it's the EGR switch, which is easily reached under the throttle body, at the t-stat gooseneck. If the code (or codes) take a while, then it's gonna be the EGR valve, which ain't the least bit easy.
2) The relays are a good place to check, but don't be surprised if the MAF is bad, too.
3) The knock sensor will code if the other things ain't right. I agree 100% with 65Z01 that fixing the first two should fix the last one. If it does not, the knock sensor is rather easy to fix.
Old Jul 13, 2005 | 12:12 PM
vader86's Avatar
vader86
Unfortunately 85 has no power relays like the rest of us, which are usually the cause of the 34.
85 has a burnoff module buried in the dash on the passenger side, kinda expensive too. Its either that or the MAF itself.
Old Jul 13, 2005 | 03:37 PM
mikey whipreck's Avatar
mikey whipreck
For how much that stupid burnoff module costs that thing should be cast in gold and jewel encrusted...
Old Jul 13, 2005 | 03:51 PM
thrills's Avatar
thrills
Moderatrix
thanks for the feedback guys. I taking one of our other cars to him tomorrow so I will talk to him then and show him these replied.
To codes 32, 34 and 43
