My opti went south! I opened it and found out that the rotor was destroyed !
Seems like the metal part got loose and crashed into one of the optispark cap wall.
Is this a comon issue? The optispark had about 200 miles on it.
How can I prevent it from happening again, optis are expensive and instalation is really time consuming.
No it is not common for this to happen.If you go above 6000rpm they may fail did you over rev it? There are onlt 2 upgrades available. One is the Dynaspark( I have one) that is a better opti all around or you can go with a Delteq/ Ltcc system that eliminates the rotor of the opti and only uses the optical pickup.Dynaspark is $500 Delteq/LTCC set up is around $600.
I would be concerned as to why it failed. There could be other issues that need resolved underneath the timing cover.Try to find another forum member near you to give you some help and advice on this. Good luck.
I am very confused. . If the rotor failed it can happen again. So what is your advise: go for a Dynaspark which is supposed to be bulletproof or Delteq that only uses the optical part without using the cap and rotor.
I understand Dynaspark uses OEM cap and rotor, so that would be a loose end.
I did not understand very much the solution using washers. I imagine that this would cause the cap to leave a space that would cause water to get into the optispark with ease! . Please let me know if Dynaspark is the way to go. After all the OEM Opti was new!
I love the car but really hate the opti, I am sure a lot of owners would like to kick the Vette staff involved in the opti creation!
I can only provide the info it is up to you to make a choice.I like the dynaspark others like the delteq. I really would want to know why it happened first before I replaced it myself.Dynasparks are not totally bullet proof but mutch better than stock.
When you took it apart did the screws come loose or did the rotor break? If they came loose you may want to try just a cap and rotor with the Loctite on the screws.If it happens again them I would upgrade but only after finding out why. Another forum member is having some issues with both Opti and Dynaspark failure in his case it seems to be something behind the timing cover killing them.
Yes there are lotsa C4 owners that would like to meet the Opti engineers in a dark alley somewhere . Good Luck
Well, when I opened the opti, I found that the rotor was broken from the back part and the metal parts that are used to transfer the spark where loose, and one was embedded in the rotor cap. By the way, the rotor is perfectly installed with the two screws. I t was the top that broke and even damaged the rotor cap.
At the time the failure occured I was at full throttle and the engine stopped working suddenly. I understand that if I over revved the engine it has a limiter so no engine damage is caused, right?
Could vibration from a balancer cause the rotor to be destroyed?
Maybe Delteq is the way to go, because the rotor is what failed.
Either a flaw in the rotor or major vibration probably caused it. You are right there is a rev limiter but they can be changed via programming.Do you know if your engine vibrates a lot?Nothing is bulletproof including Delteq and be aware the Delteq supporters are like born agains but from the polls I have taken there are not that many out there.Probably just as many Dynaspark owners. At this point if your still torn down and everthing else inside the opti looks good( gotta watch out for broken pieces here) and the cap is in one piece Delteq Might be a good option.
Remember to RTV the cap and plug area when re assembling. PM Bogus about his setup he is very knowledgable on the Delteq/LTCC setups.
Good Luck
I had the same thing happen to me. My car is definately modified though, and I believe that my cam pin was to long for the newer style opti and it was putting pressure on it and causing some vibration. I wouldn't think that this is a "common" issue, especially on stock cars. Good luck!!
They will bypass the use of high voltage, eliminating the rotor.
Also, when getting GM parts, try contacting Chris May at Superior Chevy, in Kansas, 1.800.728.8267. I don't know about exporting to Mexico, but it should be cheaper then what you are paying now.
