air pump bypass question?
Old Jul 13, 2005 | 10:45 PM
91superram's Avatar
91superram
Default air pump bypass question?
What are the HP gains when a air pump eliminator kit is installed in a L98
Old Jul 13, 2005 | 10:46 PM
vader86's Avatar
vader86
zero
Old Jul 14, 2005 | 01:03 PM
LaVidaLoca's Avatar
LaVidaLoca
Originally Posted by vader86
zero
I am a little more optomistic than that!! Maybe 0 to 1 HP.
Old Jul 14, 2005 | 03:47 PM
TA's Avatar
TA
Very little gain if any, but damn there's a lot more room when working under the hood.
Old Jul 14, 2005 | 03:58 PM
AZC4Guy's Avatar
AZC4Guy
Well, you get rid of some weight, at least. Smog pump = ugly.
Old Jul 14, 2005 | 04:21 PM
korvette4u's Avatar
korvette4u
it was mentioned in several threads that the air pump does use about 5hp when operating...to say no increase in hp when it is absent is not EXACtly true.
some advantages to eliminate air pump includes engine performance
(up to at least 5hp , if not more), compartment clauder, alternate choices between Air pump eliminators or replacing stock pump...the decision is totally up to you.. i have choosen to remove air pump and replaced it with my version of an Air Pump elimnator..
Old Jul 14, 2005 | 04:50 PM
l1sikes's Avatar
l1sikes
You get zero increase in H.P., you get a small decrease in parasitic H.P.
Old Jul 14, 2005 | 05:16 PM
vader86's Avatar
vader86
Saying that it uses power is false, when you think about the fact that the ECM kills everything when you got WOT, at which point no emissions equipment works. No EGR, AIR, and no O2 readings.
And the pulley thats on it already is already freely moving, so youre not getting back your parasitic loss.
Old Jul 14, 2005 | 06:32 PM
korvette4u's Avatar
korvette4u
saying that the air pump uses zero hp(power) is false!....in other words you are telling me that is "air pump" is an effiency device and operates by it self....well now that's interesting. oh , of course WE ALL travel at wide open throttle most of the time ....i think a little common sense is the issue....
first the pump does not free wheel, once in operation the vains inside are forced to the pump wall producing positive air pressure which in turn is diverted as required or demanded by ECM..but it does not stop pumping. any essive air flow is diverted to atomsphere...
i do agree that it (air pump) is parasidic using some hp (power) to make it operational..this is a given.
Old Jul 14, 2005 | 06:38 PM
kpforce1's Avatar
kpforce1
Well, i didn't buy an eliminator kit... i just took the pump off and used a string the find the right lenght belt that would work without the air pump installed... $120 for some bull ****.. hell with that. Shorter belt works just fine for me.
Old Jul 14, 2005 | 09:45 PM
vader86's Avatar
vader86
READ WHAT IM TELLING YOU
No, when you want your horsepower, its ALL there. At WOT everything gets cut off, EGR/AIR/Compressor, everything. So compared to the eliminator you should get zero hp, since the pulley on the AIR is as freely spinning as the eliminator's pulley.
Anything sitting there will eat parasitically at anything less than WOT.
If you get rid of it entirely and get a shorter belt, then you get the power back. Otherwise you dont get sh** besides weight savings and aesthetics.
Old Jul 15, 2005 | 12:07 AM
korvette4u's Avatar
korvette4u
as i said before, the air pump once in operation (spinning) forces the vanes into the pump walls..the Pump does not stop compressing air. the ECM controls (@WOT) the divertor valves, NOT THE PUMP! it either goes to atomsphere or back into the emissions system, . in short it still pumps . this operation does not compare to an eliminator which free wheels all the time. you may say both are parasitic, but each unit should be dyno'ed to measure exactly how much hp is wasted ! i sure this has been done somewhere....
using a shorter belt may not simple cure the parasite, as there is definately a clearance problem. The belt passes over the power steering pump, around the altenator and then back under the water pump pulley. it is at this very area the belt has NO CLEARance as the angle /hieght of the alternator does not allow for this to be accomplished. hence an alturnative solution "air pump eliminator". some keep the hieght at the same elevation as the AIR PUMP, while others will drop the belt lower into the motor compartment.
Old Jul 15, 2005 | 12:58 AM
vader86's Avatar
vader86
What youre saying is that the AIR is still sitting there and the drivebelt spinning it always spinning the vanes....well whoopee doo, if you gut the pump you get rid of the vanes and you just have a wheel.
If you dont gut the pump, you still have a wheel, that thing doesn't give me any resistance when I spin it by hand.
Maybe your eliminator is made from space-age technology with no measureable coefficient of friction, but that thing isnt going to give me anything I can measure. I have seen people dyno them, and get nothing whatsoever, and those that have cannot say that the eliminator gave them the power by itself.
Old Jul 15, 2005 | 02:26 AM
korvette4u's Avatar
korvette4u
vader86> i do admire your techicial skills
if you gut the pump...no vanes result in no air compression..this then is the same as FREE WHEEL i agree to this..you gots it finally...however there is drag both in air pump without vanes AND air pump Eliminator.. the friction coefficient is SLighly less with the eliminator (only one bearing to turn) as would be two bearings with the air pump(front and rear, results in definate more fiction). doubt very much "space-age technology" ,spinning by hand , is accurate enough to determine. however, actual testing would yield drag coeifficient for either..
BTW; i have a uncle whom knows a friend, that is a friend of a friend, that know the same guys that you speak of . just joking, perhaps proof is in the pudding?
To air pump bypass question?
