From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
If you check your RPO codes and compare it to Bogus' FAQ at the top of the page, you will get more than enough info. Without the RPO codes... there is no definite answer.
Search gor 'G' codes.
If you have a G92 code you have a performance axle ratio.
Then you have to find the other 'G' code .
My next G code is G....Idon't remember and it is a 2.73 ratio differential. (so the base should be a 2.59).
Now I have a 3.54.
-Beppe-
