L98 Head Bolts
Old Jul 14, 2005 | 03:04 PM
dmyers's Avatar
dmyers
From: A place where chickens can cross the road without having their motives questioned
Default L98 Head Bolts
Are the head bolts on the L98 reusable? I was told by the guy at the machine shop where I took my heads that the bolts might be stretch bolts and need to be replaced prior to reinstalling the heads. Does this ring any bells or should I just change the bolts as a matter of good practice?
Old Jul 14, 2005 | 03:11 PM
randy814u's Avatar
randy814u
I have reused head bolts when I was younger with no problems, but now I put new ones on, just so I don't have to worry about a problem.
I feel it is cheap insurance. Randy
Old Jul 14, 2005 | 03:28 PM
STL94LT1's Avatar
STL94LT1
I reused the torque-to-yield head bolts on my LT1, and have ran the car hard for almost three years without a problem. Would I do it again, probably not. It's really not worth the risk.
Old Jul 14, 2005 | 03:47 PM
scorp508's Avatar
scorp508
For $70 its cheap insurance.
Old Jul 14, 2005 | 04:23 PM
dmyers's Avatar
dmyers
Where can I get them for $70 and do you have a part number by chance?
korvette4u's Avatar
korvette4u
although i have reused old bolts...
Old Jul 14, 2005 | 05:13 PM
Dougs 90's Avatar
Dougs 90
I just ordered a set from summit racing for my AFR 195 heads I am planning on installing.
ARP-134-2701 SB Chevy 12 pt Head Bolt set $59.88
Doug
Old Jul 14, 2005 | 05:21 PM
V's Vette's Avatar
V's Vette
Check both Summit and Jegs -- the p/n for my stock '89's heads are 134-3601 (hex head). The price by Summit as of today is: $53.88
Old Jul 16, 2005 | 12:57 PM
dmyers's Avatar
dmyers
Thanks for the p/n and the info all.
Old Jul 17, 2005 | 09:23 AM
V's Vette's Avatar
V's Vette
Is there any advantage to using either 6 point or 12 point bolts?
Old Jul 17, 2005 | 11:03 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
When I rebuilt my engine I figured I could get by without replacing the headbolts. I always use anti-sieze for installation to ensure sealing and lubrication of threads. I got (believe this or not) ALL of them torqued down fine except the very last bolt. This sob broke! So, I had to get another set of head gaskets AND a new set of head bolts. Do replace them, you'll be much happier. I got mine from NAPA for about $70 as was stated but I would follow Dougs 90's advice and get the ARP bolts, they are re-usable. I would have but didn't want to wait for them to come in, NAPA was faster.
Old Jul 17, 2005 | 04:08 PM
Davemc1963-87conv's Avatar
Davemc1963-87conv
The part # for 12 point heads is 134-3701 if you are using stock heads.
The 12 point heads are smaller and easier to get on in tight spaces.
If you are running a full roller rocker arm for example, you probably wont get on the head bolts near the rocker arms to retorque with a 6 point hex head. You should be able to with a 12 point head and a 'slim' socket. for the $3 or $4 difference, go for the 12 point heads, unless you want/need it to look stock. JMO
Old Mar 18, 2020 | 11:15 PM
Tvette99's Avatar
Tvette99
Default 134 3701
are these for the cast iron or aluminum heads what year l98 are these bolts good for ????
To L98 Head Bolts
