Speedo gear source
Old Jul 15, 2005 | 11:52 AM
Black84's Avatar
Black84
Default Speedo gear source
I am putting in a D44 - 3.45:1, replacing the stock D36 - 3.07:1 on my 84 with A4 and need the speedometer gear. Can anyone point me in the right direction to a source?
Thanks in advance for your help...
Old Jul 15, 2005 | 05:19 PM
93 ragtop's Avatar
93 ragtop
The GM dealer is a good source for the gear. They are cheap. CFI-EFI has helped many on here figure the correct ratio. He may see this post and add to it with part nos. You need your tire size to do the calculations.
Old Jul 15, 2005 | 05:39 PM
aqualung's Avatar
aqualung
I am also looking for a speedo gear for my 92 when I went from 3.45 to 4.10. It drives me crazy not knowing how fast I am really going.
Apparently in the 92 ECM program you cannot edit for gear changes. Later years you can.
Any help would be appreciated.
Old Jul 15, 2005 | 05:49 PM
STL94LT1's Avatar
STL94LT1
Try Exotic Muscle.
http://exoticmuscle.com/webpage.php?...SEL=DRIVETRAIN
Old Jul 15, 2005 | 06:44 PM
CFI-EFI's Avatar
CFI-EFI
Both you guys got lucky. Of the three pieces that often need to be changed, the drive gear, the driven gear, and the VSS, each of you only has to change one item.
Black84,
You have to replace the red, 17 tooth, drive gear with a grey, 15 tooth drive gear, part number, 8642620.
Aqualung,
All you have to change is your driven gear. Swap out your green, 42 tooth, driven gear for a light blue, 45 tooth driven gear, part number 25513052.
As far as I know the best prices on these parts come from a GM dealer. Particularly Superior Chevrolet.
RACE ON!!!
Old Jul 17, 2005 | 09:59 PM
aqualung's Avatar
aqualung
Black84,
Aqualung,
RACE ON!!!
Hey thanks CFI-EFI. Just the help I was looking for.
Old Jul 17, 2005 | 11:00 PM
BlackC6LS3's Avatar
BlackC6LS3
hey CFIEFI i will be going from a D36 with 2.59's to a D44 with 3.45's...what do i need to do?
Old Jul 18, 2005 | 12:14 AM
Dougs 90's Avatar
Dougs 90
I believe you will have to change all three, the drive, and driven gears, and also the speed sensor. Going from 2.59 to 3.54 I needed a gray and purple gear. Looks like you need a grey and green gear
Check Here
More good info!!!
look down the page and there is a calculator based on tire diameter and everything for the 700 r4
Old Jul 18, 2005 | 01:50 AM
corvette90-1's Avatar
corvette90-1
search the net for performance automotive transmission center..they have speedo gears too
Old Jul 18, 2005 | 11:24 AM
CFI-EFI's Avatar
CFI-EFI
A year and a trans would have helped. The driven gear can change depending on the year, in a manual. Since you had 2.59 gears and a Dana 36, I am going to assume this is an automatic. All three pieces have to be changed. You will need a grey, 15 tooth, drive gear, part number 8642620, a green, a 42 tooth, driven gear, part number 25513049, and a different VSS to accommodate the larger driven gear. For 1984 to 1990, the VSS has to be changed to a 25007308. Good luck. It is my understanding that the 25007308 is discontinued. You may find a dealer with some old stock or find one in a wrecking yard. For 1991 through 1993, use VSS number 10456092.
RACE ON!!!
To Speedo gear source
