Smell gas
Old Jul 15, 2005 | 12:16 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Smell gas
On the way to work, stepped on the gas pretty firm, but not real hard. As I got up to the speed limit(40), i started easing back. That is when I started smelling gas and it smelled like someone dumped it in the cabin. I have smelled it before, but it was always just a faint smell.
Anybody got any ideas what it might be??
Old Jul 15, 2005 | 02:56 PM
rick lambert's Avatar
rick lambert
Someone else had that problem once-they forgot to put their gas cap on. You could also check your charcoal cannister and the rubber gasket
going to the fuel tank. All this assuming you've checked for gas leaks in the engine compartment.
Old Jul 15, 2005 | 03:57 PM
Dave89CC2's Avatar
Dave89CC2
Cruise-In VII Veteran
Gas lines run right under the passenger side door. Has your car been on a lift lately? Sometimes that will crush those lines.
Also, when this happened, were your windows up or down? Was the top off?
Old Jul 15, 2005 | 05:22 PM
Skippy's Avatar
Skippy
Maybe a cracked fuel injector? My 91 did this.
Old Jul 16, 2005 | 11:45 AM
kevettom's Avatar
kevettom
Check by the left rear wheel. There is a small rubber vapor line from the tank that may be cracked. Gave me an intermittent strong gas smell.
Old Jul 16, 2005 | 12:06 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Sounds like EVAP stuff going bad, its sorta hard to diagnose as a home mechanic. I would just look for rotted lines.
To Smell gas
