Electrical issues need help
Old Jul 15, 2005 | 05:24 PM
Phantom90's Avatar
Phantom90
Default Electrical issues need help
OK last night I posted about an electrical problem. Today I got the battery replaced and the car starts fine.
BUT something is wrong with the electrical aspects of the car. Sometimes the radio will work some times it will not, sometimes the AC will work and sometimes not work, the power antennae goes up sometimes it stays up after I turn the car off. Some times the speakers work other times they dont. Same with the lights behind the instrument panel.
So I know everything is in working order it is just a bigger problem that they do not work at the same time. This is very odd it is like my car is possessed.
Is there something I need to replace? WHat do I do? I need help there is no answer in the trouble shooting section of the manual.
Old Jul 15, 2005 | 06:21 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It sounds like you have a loose power or ground lead somewhere.
Start by inspecting the battery terminals and leads and move to the grounds.
Old Jul 15, 2005 | 06:35 PM
ittlfly's Avatar
ittlfly
Check the wiring diagrams in your Helms to see where those non working items have a common junction. It's from that junction back to the power source (including its grounds ) is where the problem lies.
Old Sep 13, 2005 | 10:50 PM
Phantom90's Avatar
Phantom90
TTT
Its now 2 months later and I am driving the car to campus daily.
The electrical problem is still present. The AC does not work. The radio also will not turn on. They have worked in the past they just do not work any more. somebody help please.
Old Sep 13, 2005 | 11:25 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Did you check your Helm factory service manual 2 months ago? You cannot diagnose this kind of electrical problem from long distance unless someone spends a lot of time going through the manual for you.The manual has the electrical drawings in it and if you want it fixed I suggest you get to it.
Check all your grounds The manual will tell you where.
To Electrical issues need help
