miniram help!!!- really
Old Jul 16, 2005 | 08:50 AM
lawcorvette's Avatar
lawcorvette
Default miniram help!!!- really
I lost the fuel line fittings.. called up TPIS had a rush order sent,,, they sent me -6 Male to 16mm female and -6 male to 18mm fittings but I have no way to attach the female end of those fittings to the fuel line and filter.. what I needed was a male to male fitting... where can I get one. Their invoice says 16mm/18mm all I can find in the summit catalogs and jegs is in standard for fuel line fittings.
I
Old Jul 16, 2005 | 09:09 AM
danno85's Avatar
danno85
Are you hooking up the TPIS supplied metal fuel lines to the stock fuel hoses (the fuel hoses that originally connected to the TPI system), or are you making up new lines to run from the mini-ram rails down to the fuel filter/return line at the frame rail. If the latter, which is what I did, Accel makes a pair of fittings that you need. Take a look at the Accel catalog on the Mr. Gasket web site to find what you need and get the part number, then order from Summit or Jegs. You probably won't find them listed in the Summit/Jegs catalog - they don't publish every item they stock.
If you need some more help with that I'll try to look up the part numbers for you.
Dan
Old Jul 16, 2005 | 09:16 AM
-=Jeff=-'s Avatar
-=Jeff=-
This is what you need
Accel PN 74730
TPI Super Ram, Street Ram, Fuel Rail Fitting Kit
1 3/8 Saginaw to 6AN
1 5/16 Saginaw to 6AN . . . . . . . . . . . . . .74730
Taken from Accel's catalog, they are Male to Male
at Summit Racing it is PN ACC-74730
To miniram help!!!- really
