well if you are doing 126mph,than you will have to have near 500hp in a 3300 pound car.G-techs usually read a few mph high.and I just have to say,according to your sig,having over 400hp with siamese runners in a N/A 350 is
What year is the car? What tires, what launch technique?
The ET seem's really fast for the HP, and the MPH is insanely high. I had a G-tech and ran it at the track a couple times. The ET was about .2 fast, and it was 6 mph fast. I ran 2 G-techs at the same time once and came up with completely different results.
I wouldn't put too much stock in the time/mph being accurate, however I found that they are very consistent. If all you're using it for is a tool to gauge wether mods are helping or hurting, they're great. No real sunbstitute for the track though, IMO.
Adrian! I've been waiting to hear some news about your motor! 365 RWHP through a 350CI TPI is damn impressive! Now get that thing on a dyno and get some solid numbers!
The car is a 1990 L98 6 speed running Shell Optimax (98 octane ) tyres 275/40/17 , amb temp 65f launch tec = about 3500 rpm's and drop the clutch
Only using the Gtech as a rough guide to tuning mods, there arn't many strips here in the UK and the closest one is about 250 miles away
Just wanted to post the # to see if you guys think that she is running about right.
Just waiting for prom number 2 to arrive from Merle and hopefully that should sort out my BLM's , then I will be straight up to the dyno
my opinon is that no way that combo can put out 365rwhp. And no way the car can trap 126mph in 1/4. The kind combo can trap that type speed is 383ci stroker motor with super ram setup or even a 406ci + motor to do that. Unless your are supercharged, but you are not.
Bruce
I'll bet that it is, he has some very well put together components...one specifically that I'll bet no one here has seen as of yet (which is why I've been wanting numbers from him for a while!). I'll hold off until I see actual dyno numbers, but at the moment I'm not suprised one bit!
EDIT: I agree about the trap speed though, but it's a G-Tech and I don't know how accurate they are on traps, but I've heard they are pretty accurate on times
They are about 100 at idle and slowly creap up to 128 at about 70% throttle and then stay at 128 all the way to WOT
you are way to rich and the 128's you are seeing above 70% throttle are probably just PE mode locking the BLM's in at 128, what arethe O2 readings?. You realy need this thing tuned before you keep driving it because you are just dumpimg way to much fuel and may cause engine problems in short order if not.
Your car probably has around 300ish rwhp. It will probably run 110-112ish on a good day.
I personally like Gtechs when you compare the numbers against themselves when modding your car but I put no faith in them as a true indicator of what a car will do.
Around 5 years ago we tried to gtech our motorcycles. I had a FZR1000, one buddy had a FZR600 and the other guy has some POS Kawasaki 600.
The guy came back into the yard with his KOW and the Gtech was flashing some 9 sec # @ 145 mph. We had a pretty good laugh at that.
G-techs have never worked on bikes...especially the older ones!
Really? You mean that 600 Kawa wasn't running 145????
Amazingly enough, nope I don't think it was! They are fairly accurate on cars, from what I have been told in terms of E.T's, but not so much with the MPH.
They don't work on bikes because they need to be kept level and it calculates the time and MPH based on the angle and speed it was tilted off center...a bike has much more drastic movement than a car does on acceleration.
This was done with my previous car. As you can see the trap speed is different than the time slip. This G-Tech Pro is not the most current model. It is the one with the red LED display.
You must make sure the unit is straght and level. Also, if you are not running at the drag strip then you need to do 2 or 3 runs in one direction and 2 or 3 runs in the other. Then you average them out. You can just make one run and expect it to be an accurate reading.
So take off 5-6mph on your trap to get a more accurate comparison.
You must make sure the unit is straght and level. Also, if you are not running at the drag strip then you need to do 2 or 3 run in one direction and 2 or 3 run in the other. Then you average them out. You can't just make one run and expect it to be an accurate reading.
