700R4 leaks - sometimes
Old Jul 17, 2005 | 10:19 AM
Mike263's Avatar
Mike263
Default 700R4 leaks - sometimes
If the 86 sits for more than 3 days it leaves a small puddle of tranny fluid on the garage floor. I normally drive it everyday and it doesn't leak a drop. The tranny was rebuilt 30k miles ago and this leak just started. Why would it leak (about a pint) only if it is not driven for 3 days or more?
Old Jul 17, 2005 | 10:27 AM
Pete K's Avatar
Pete K
Sometimes, the fluid in the torque convertor will drain out past the front seal when the car sits. Also, when rebuilding a trans most guys will not change the seal that the shifter shaft passes through. This could also be the problem. The shifter seal drove my buddy crazy for years. He put a pan under it because it slopped up the garage a bit.
Old Jul 17, 2005 | 10:59 AM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by Mike263
If the 86 sits for more than 3 days it leaves a small puddle of tranny fluid on the garage floor....
A pint is a "small amount"? The "Add" mark on your dipstick is at a pint. That sounds like a pretty major leak, to me.
RACE ON!!!
Old Jul 17, 2005 | 12:11 PM
RWDsmoke's Avatar
RWDsmoke
Mine was leaking like that. It was the dipstick tube grommet.
Old Jul 17, 2005 | 07:45 PM
Mike263's Avatar
Mike263
RACE ON!!!
Yeah a pint is a lot. But it only leaks the pint then the leak stops.
Old Jul 17, 2005 | 07:48 PM
Mike263's Avatar
Mike263
Thanks! The torque converter draining sounds like it might be my problem.
Old Jul 18, 2005 | 10:47 AM
kpforce1's Avatar
kpforce1
Same problem I had.... and it would leak a Sh*t load, especially if I was on an incline.
Old Jul 18, 2005 | 06:04 PM
goldeneye_vet's Avatar
goldeneye_vet
Shift seal! Had the same problem on mine. Some yahoo who installed it years ago didn't do it right and it leaks down from the shift seal and around the tranny pan to where it looks like its coming from the rear main seal or your oil pan in the back toward the tranny. Replaced it and some other goodies this past spring and no more leaks!
Old Jul 18, 2005 | 10:23 PM
Rick86's Avatar
Rick86
You have too determine where the leak is coming from then we might be able to better diagnose it for you. My quess is it is overfilled. Have you checked the level on level ground at normal operating temp?
To 700R4 leaks - sometimes
