MAIN cooling fan and relay problem exposed....
Old Jul 17, 2005 | 12:13 PM
korvette4u's Avatar
korvette4u
Default MAIN cooling fan and relay problem exposed....
SYMPTOM:determine to find out why my fan relay was over heating and burning out.
PROBLEM:::main fan motor was dragging (lack of lube over the years), brushes contaminated with dirt. intermittent failure( when it is suppose to be running)
SOLUTION: dissassembled, checked the comutater to ground (check for circuit to ground, shorts). remachined/resurfaced, clean brush holders, installed new front bearing, cleaned and re lube rear bearing, reassembled. current draw is now less 8 amps, where before was in excess of 15 amps. total time for repair was about 1 1/2 hours...relay/fan are now cooler when operating.
Old Jul 17, 2005 | 12:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Good trouble shooting job; thanks for the follow up solution.
Old Jul 17, 2005 | 12:38 PM
korvette4u's Avatar
korvette4u
thanks, great to hear from you 65ZO1..its nice to be back after some creuling 67 days of work..
To MAIN cooling fan and relay problem exposed....
