I just bought myself an '88 Vette last week. It always seems to run really hot, even though the temperature gauges have it within a reasonable temp. (Usually between 200-210 for Coolant, and about 220 for oil). Yet when I get out of my car, I can feel the heat from the engine coming out of the side vents on the fenders. I went to change my spark plugs the other day, and even after sitting there for 3 and a half hours in the evening, it was still pretty hot to the touch. Is this normal? I'm going to try cleaning my radiator tomorrow and see if that helps any, but even though my dad says it's all fine, I don't think it is. He's not the one burning his hand on my engine =P
Normal for stock. You could search up the thread, cowl induction. Cutting the front weatherstrip away lets more heat out. If you want to work on the car after driving it, open the hood, pointing a fan at the engine is good to.
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Normal temps. Nothing to worry about. When you get a free afternoon, try to clean the crap off in between the radiator and the condenser to ensure maximum efficiency in your cooling system.
Absolutely normal. My '88 runs about 10-20 degrees below that but I use Redline watter wetter which is supposed to drop coolant temps by 10-20 degrees.
