SuperRam + TV cable = Kinky
Old Jul 17, 2005 | 04:53 PM
RocketSled's Avatar
RocketSled
Default SuperRam + TV cable = Kinky
(I can't be the only person to experience this)
I've got a Superram'd 383 that's been on the lift for a good 10 months awaiting work. Now that it's back on the road I've found that the TV cable isn't sliding smoothly. I'm pretty sure it's due to the sharp bend the cable takes as it goes under the superram.
Any hints on making the angle less sharp? The bracket doesn't look like it'd take much slotting (to change the angle) the way it's made, so I'm not entirely sure that's the solution.
Was there a replacement bracket for this situation?
Old Jul 17, 2005 | 04:58 PM
65coop's Avatar
65coop
St. Jude Donor '05
My SR came with a new bracket, but it still in a bind a tad... but it seems to work ok...
Old Jul 17, 2005 | 05:04 PM
RocketSled's Avatar
RocketSled
Looks like that's what I get for buying an ebay intake. I'll be calling Lingy or Accel tomorrow.
Old Jul 17, 2005 | 05:22 PM
65coop's Avatar
65coop
St. Jude Donor '05
Did you try to use the one from your TPI?
I think the SR part has a little more angle to it...
Old Jul 17, 2005 | 05:29 PM
Caboboy's Avatar
Caboboy
Here's a pic of mine. I'm using an adapter because of the nitrous plate TB spacer and that appears to lengthen it enough to lessen the angle
Old Jul 17, 2005 | 05:39 PM
65coop's Avatar
65coop
St. Jude Donor '05
Sweet looking SR!!
You have good taste in colors
Old Jul 17, 2005 | 06:37 PM
Caboboy's Avatar
Caboboy
Originally Posted by 65coop
Sweet looking SR!!
What a kick! That's an awesome SR ya got there yourself!
Old Jul 18, 2005 | 10:05 AM
RocketSled's Avatar
RocketSled
yeah, I'm reusing the old one...looks like there's an obvious solution here.
Old Jul 18, 2005 | 10:06 AM
RocketSled's Avatar
RocketSled
Is that an Oven Thermometer hanging out near your brake booster?
Old Jul 18, 2005 | 10:44 AM
Caboboy's Avatar
Caboboy
Yeah, I wanted to see how warm my underhood temps were getting. I found I usually ran at Beef Medium to Beef Well. I read somewhere that you get more power if you can cool it off to Beef Rare..... I think it was in a book by Smokey Yunick or something
Old Jul 19, 2005 | 01:49 AM
65coop's Avatar
65coop
St. Jude Donor '05
Old Jul 19, 2005 | 12:28 PM
bigjack's Avatar
bigjack
Default Purpose of TV cable?
Can anyone tell me the purpose of the TV cable? Can it be delted without consequence? Thanks, Jack
Old Jul 19, 2005 | 12:37 PM
RocketSled's Avatar
RocketSled
If by no consequence to mean = Transmission rebuild in less than 10 miles!
That cable lets the tranny know how much throttle you're using. It adjusts clutch force and shift timing as a result.
Old Jul 19, 2005 | 01:56 PM
MrNuke's Avatar
MrNuke
THAt cracked me up..
To the original poster = You'll need to get the bracket from an 88+ L98, which has a higher angle than the early TPI GM brackets. Worked for me..
Old Jul 19, 2005 | 03:02 PM
Corvette0096's Avatar
Corvette0096
The beauty of the SR..
To SuperRam + TV cable = Kinky
